Someone else may have done this but we were very curious to see the exact effects of Pioneers MCAAACAACCCAACCCAACCC effects on a systems overall frequency response. I had heard a lot about it here so and was wondering how well it worked.
So we took Sencores SP295 Contractor version sound analyzer to a showroom where the 49TX was running a Klipsch reference system. Not being familiar with the product as we are not Elite dealers we found it very easy to use without a manual. We didn't have a lot of time to work with and may not have done everything exactly right but doing a quick and dirty RTA we were impressed.
First, we turned off the MCACC and then did a manual setup of the levels and speaker distances. The Sub was set about 20 db too high (surprise). Then we pumped pink noise through all the channels via Avia's 5 channel wideband pinknoise. Then took a before MCACC real time analysis.
We then we hooked up the mic and let the Auto Calibration do it's thing. Then took another RTA sample as our after graph. The spl levels in the before and after are not exactly the same but you can see that the before has a very bad 13 db dip and peak in the 30-50 hz region and several other very uneven area's in the bass response up to about 150hz. The blue is the after and is much much better as you can see.
I came away very impressed with how well this works and now hope that Pioneer continues it's development. Sad thing is that the coolness of such a system is lost on the average HT consumer. What I'd really like to see is Pioneer liscense it to other companies as well. I could be wrong but I don't thing the smaller OEM type companies have the R&D dollars to make calibraiton systems like this for their 5k ish seperates so to see it liscened to companies like Anthem, B&K, Sunfire, Rotel, Adcom, etc. would be my hope if in fact they cannot come up with something similiar.
Anyway awesome stuff and it is just going to get better I hope. The Black line is the before
http://www.audiovisionsystems.com/images/mcacc rta.jpg
