AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Orange County, CA - Cox
Orange County, CA - Cox - Page 229
post #6841 of 7240
Question, can all 500GB be used yet on the newer Digital Boxes?
post #6842 of 7240
Pretty sure Cox is still blocking esata and usb.
post #6843 of 7240
That would be for external drives, the all Digital units have been coming with a 500GB internal HD, but due to a Software Flag of some sort, only 160GB could be accessed. We have newer software now, was wondering if that removed the flag.
post #6844 of 7240
That would be Motorola blocking seats box or cisco wouldn't work with it.
post #6845 of 7240
I have both Digital Cable and Internet from Cox (Irvine). If I cancel digital cable and keep the internet, will I be able to receive clear unencrypted QAM?
Thinking of building a media center with HDHomeRun and trying to figure out if I need to install an OTA antenna on the roof. I just want to receive the LA networks, and stream Netflix/Hulu/Amazon/etc. for everything else.
post #6846 of 7240
That tuner is for cable-card stuff really though it can decrypt clear QAM. There are tuners that just do clear QAM.
http://www.newegg.com/Product/Produc...82E16815116028
And yes you should be able to get basic cable with digital.
post #6847 of 7240
So my Tivo popped up with a whole slew of new channels today. Some are working with the tuning adapter, some not. I went through all the HD channels to test what I'm getting and not getting.
Working:
891 DIYHD
892 COOKHD
893 HUBHD
894 (unlabeled)
895 OUTHD2
1028 WGNHD
1051 TWCHD
1103 IDHD
1337 TENISHD
1346 BBCAHD
Not Working:
785 NFLNRZD
798 GAME HD
799 CSDINHD
870 STZIBHP
871 STRCHP
877 SHWXPHD
879 HBOCPHD
880 HBOZPHD
881 HBO2HD
882 HBOSGHD
883 HBOFHD
884 HBOLAHD
887 SHOCPHD
888 TMCHD
889 STZCHD
890 STZKHD
1045 HLNHD
1047 (unlabeled)
1068 TCMHD
1105 OWNHD
1284 STZEHD
1352 TRUTV
1363 NGWILDH
1371 WEHD
1394 GALA
1654 TEAM HD
1672 (unlabeled)
None of the 1900 numbered MC channels are working for me either.
I don't sub to Cimemax and didn't try any of those channels, or any paid sports channels. I do subscribe to HBO, Showtime and Starz.
Can anyone with a TA report back if they are getting any of the channels I'm not getting?
I am thrilled with BBC HD, but I am really getting perturbed about all these channels that should be part of my package that I can't get -- especially the premiums.
post #6848 of 7240
Working:
891 DIYHD
892 COOKHD
893 HUBHD
894 (unlabeled)
895 OUTHD2
1028 WGNHD
1051 TWCHD
1103 IDHD
1337 TENISHD
1346 BBCAHD
Not Working:
785 NFLNRZD
798 GAME HD
799 CSDINHD
870 STZIBHP
871 STRCHP
877 SHWXPHD
879 HBOCPHD
880 HBOZPHD
881 HBO2HD
882 HBOSGHD
883 HBOFHD
884 HBOLAHD
887 SHOCPHD
888 TMCHD
889 STZCHD
890 STZKHD
1045 HLNHD
1047 (unlabeled)
1068 TCMHD
1105 OWNHD
1284 STZEHD
1352 TRUTV
1363 NGWILDH
1371 WEHD
1394 GALA
1654 TEAM HD
1672 (unlabeled)
Those are the channels that come with the whole dvr.
post #6849 of 7240
Only some of them are the WHDVR Plus Package channels. The rest are new and are not tied to the Plus Package.
http://ww2.cox.com/residential/orang...-lineup.cox#17
moyekj has reported previously he receives all the Plus Package channels on his TiVos.
post #6850 of 7240
I don't understand at all why I would get some of the plus package -- 891 through 895 -- but not get the premiums in the same package when I pay for those channels.
Some of the new channels are not listed at all, and there doesn't seem to be a rhyme or reason as to what comes in and what doesn't. Why do I get 1103 but not 1105? Why 1346 but not 1363?
post #6851 of 7240
I believe it is the way Cox chose to set-up their billing system, where they require the WHDVR code on the account to authorize certain channels. CableCard customers need to start complaining if they are not receiving all the channels in their packages.
post #6852 of 7240
Well, after venting my spleen a bit on Twitter, a Cox rep called me.
All of the HD channels will be moving to the 1000's in December, and the new channels are mostly for testing purposes. What cable card users have now should smooth out and be the same as the regular lineup, except for the Plus Pack which we're apparently not supposed to have at all.
So I was told.
post #6853 of 7240
So I was told.
If cox is forcing the Motorola users To get the whole home Cisco hardware TiVo shouldn't get them either
post #6854 of 7240
All of the HD channels will be moving to the 1000's in December...
That has had me worried for a while. In other Cox markets where this already happened in some cases TiVo users got screwed for a while since the Guide listings were not updated in sync with the physical change. To do it properly they should start replicating all the 700 range channels in the 1000+ range before the actual switchover and then notify Tribune of the date when it will actually happen. Ideally then there should be a period of a couple of months where both 700+ and 1000+ are the same and either one can tune. I can see where us TiVo users will probably have no guide data in the 1000+ range for a while and in the meantime the 700+ channels will no longer tune. All my season passes are on 700+ channels. The other scenario is we get guide data updates where 1000+ guide data is correct but those channels don't physically tune yet thereby being screwed as well. I guess there is a slim chance that everything will work as it should...
post #6855 of 7240
Yeah, I'm not convinced it will work either.
At least they're planning on doing it in December, when many shows will be on hiatus.
post #6856 of 7240
FYI, a lot of the new channels you list like 870 for example can be tuned but are not authorized in your account. On TiVo just tune to a channel and check DVR Diagnostics. You'll see for example channel 870 is 891Mhz. i.e. If you see a frequency listed for the channel under DVR Diagnostics that means it can be tuned. If you have black/grey screen it means your account is not authorized for it (can't decrypt it).
In case of music HD channels for example they can't even be tuned (no frequency given on Diagnostics page).
I didn't check all the ones you listed, but looks like I'm seeing same as you, though in my case I don't care for or subscribe to premium channels so wouldn't expect them to be authorized for me anyway.
post #6857 of 7240
According to what the Cox rep told me, the 870's etc. are "Plus Package" and we mere mortals without the whole home DVR aren't supposed to get them -- despite the fact that I get 891-895.
As infuriating as it is that I'm not getting channels of the premiums I pay for, I could accept as part of their stated "Plus Package." But the part that drives me crazy is that I get 1028 but not 1045, and 1346 but not 1352 and 1363. It seems totally random and haphazard. It worries me that after the transition to the 1000's, I'm going to be paying for the same number of channels as before and getting fewer of them.
And there doesn't seem to be anyone at Cox willing to listen to these concerns and try to make it right.
post #6858 of 7240
Working:
891 DIYHD
892 COOKHD
893 HUBHD
894 (unlabeled)
895 OUTHD2
1028 WGNHD
1051 TWCHD
1103 IDHD
1337 TENISHD
1346 BBCAHD
Not Working:
785 NFLNRZD
798 GAME HD
799 CSDINHD
870 STZIBHP
871 STRCHP
877 SHWXPHD
879 HBOCPHD
880 HBOZPHD
881 HBO2HD
882 HBOSGHD
883 HBOFHD
884 HBOLAHD
887 SHOCPHD
888 TMCHD
889 STZCHD
890 STZKHD
1045 HLNHD
1047 (unlabeled)
1068 TCMHD
1105 OWNHD
1284 STZEHD
1352 TRUTV
1363 NGWILDH
1371 WEHD
1394 GALA
1654 TEAM HD
1672 (unlabeled)
I have just the regular motorola hd boxes but have access to some of these channels in the 1xxx range: 1028, 1047, 1051, 1103, 1337,1346, 1352, 1394. They all work except that 1047 and 1394 are GALA subscription channels. I don't see any of the 87x, 88x or 89x. All of the 19xx music stations work also.
post #6859 of 7240
Yes all the HD Music channels are now working on TiVo as well as most of the others you mention. With Tuning Adapters the TiVo gets the same channel map as regular set top boxes, so whatever Cox boxes can tune so can the TiVos with tuning adapter. It's pretty clear that the channels in 1000+ range are being added in "test" mode right now in preparation for the big switch of 700+ channels to 1000+ so things are very dynamic.
post #6860 of 7240
all of the on demand channels have been moved up to 2xxx range. It will be nice if they are actually adding the new hd channels (bbc hd, tcm hd, etc) although I guess the picture quality might suffer (again). I agree with other posts that it doesn't seem fair to not be able to get the additional premium hd feeds without paying for install of whole home cabling (even if not subscribing to it) and extra monthly fee.
post #6861 of 7240
Cox does have the 860-1000MHz range now available for new channels in addition to being able to add a whole bunch to SDV, so that combination allows a lot of room for new channels. Will be interesting to see if end of 2012 marks the end of analog channels hence freeing up a lot more space.
post #6862 of 7240
Have a few questions about the Cox system, I have the Moto. Silver HD Dvr, several years old:
1. After the interface "upgrade" we lost an Audio setting. We had narrow, medium , and wide, it's gone now. Is it automatic now???
Does the DVR have an "automatic" resolution setting that changes to what the it's receiving 720P or 1080I. I used to set it at 1080, now it seems overall to "look better" set at 720 which it seems to default to. I know my D. HD Box has a "Native" setting that switches automatically
3. I recently had Cox over as I lost about 20 HD Ch's, they checked everything and replaced most of the fittings and it helped.
I questioned the Tech about the New Cisco HD Dvr with a larger hard-drive...He said it's available but wait for at least 6 months before requesting a change-out. Lots of bugs still to be worked out.
4. He did recommend an up-grade to the New Docsis 3 Modem. Claimed much better performance, even during high use periods in the neighborhood...
Thanx
post #6863 of 7240
Don't forget the $99 install fee
post #6864 of 7240
One of my DCH-3416 boxes will no longer respond to pause, play, FF, RW, or List. So I can't watch recorded shows. It does get live TV, and the GUIDE button works. I rebooted it, and it took 5 minutes to get the guide data. It was dead until then. But now it's in the same position. I can see live TV, Guide, and change channels. But no list of recorded shows, and I can't pause or RW.
Any thing else I can try? It has a lot of recorded shows, so I hope I don't have to get a replacement.
post #6865 of 7240
Sounds like a bad remote...
post #6866 of 7240
I should have mentioned that I tried a second remote with the same results. As it turned out, the DVR did not recognize the hard drive, so the firmware disables all the DVR capabilities. Pulling the power plug fixes this temporarily, but it comes back every few days. A soft reboot does not help. I picked up a new DVR on Saturday at the Cox store, so hopefully the new one will last a while.
I did ask about the whole home DVR and asked if they had fixed the problems, and he said there would be some new Cisco boxes coming out in Jan. that would be much better, so he recommended waiting until then.
post #6867 of 7240
So here in Mission Viejo a Docsis 3 will show improvement over a Docsis 2? I'd only heard Pacific Palisades or somewhere small like that got Docsis 3 options....
post #6868 of 7240
I wonder what kind of new boxes?
post #6869 of 7240
It was a big improvement for me in Irvine. No reason it should not work well further south with Cox.
post #6870 of 7240
Cant complain with the Docsis 2 we have, on this wireless laptop its like 17Mbps down and some silly up number.....have no idea what my wired in Game Desktop is....what sort of improvement did you see?
