AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Orange County, CA - Cox
Orange County, CA - Cox - Page 242
post #7231 of 7240
Originally Posted by moyekj View Post
So the CableCard looks like it's now fine. If TA amber light is flashing then that means it's not communicating properly with headend. I'm assuming you did activate the TA as instructed over the phone right? 1st thing you should check is if the TA is properly added to your account. Then, from my understanding of previous calls to Cox there are 2 signals they can send to a TA, similar to the signals they can send to normal set top boxes. Cox should be able to determine if the TA is receiving the signals they send. Once they send the right signal(s) within 2-3 minutes the amber light should go solid and then the TiVo will go to a "TA Connected" screen and then everything should be working normally. If you can't get the TA to stop flashing then try calling a different tech as some of them are better than others.
Originally Posted by Whitearrow View Post
Yes, you need to make a phone call to another special number, different than the cable card one... let me know if they didn't give you the instruction flyer, I think I have it saved as a PDF somewhere.
I did call the "self -install" number (different than the flyer and also different from the one displayed on Tivo screen). The TA (as identified by its serial number) is supposedly properly activated and the technician sent several signals to it, none of which went through (although I don't know if they were different from each other). I'll try again in a couple of hours - maybe I'll try the number in the flyer next time although this self-install one results in a very quick, direct path to a tech. Again, thanks for all the help.
added note: I tried 2 more phone calls with same results, so am going to have to have a service call.frown.gif
Edited by twarren - 4/10/13 at 7:08pm
post #7232 of 7240
Let us know how it goes!
post #7233 of 7240
well, I guess what they say is true - 3rd time is a charm. The tech replaced TA with new TA and it just started working. He said the signal level was a little low so he also installed a booster where that feed comes in from outside. Anyway, I now get all channels - the tivo system even gets 1002 and 1009 which none of the Cox STBs have been getting for the last couple of years. I also discovered a "new" channel - 1790 (ESPN 3D) which I guess must be part of the plus pack (unfortunately tivo is not on my 3d enabled tv because I need VOD there). So, for now at least, tivo is working great. I really like their guide (and ui in general).
thanks again for all the advice.
post #7234 of 7240
1790 was just added this week, along with a bunch of sports-sounding channels that I didn't may any attention to. Glad everything is working now!
post #7235 of 7240
Both my TA's got hit by Cox again overnight. It left both Tivo's in the discovery page for connecting the TA. I accepted the change and everything was fine.
post #7236 of 7240
Yup, both of mine too.
post #7237 of 7240
Looks like Cox moved 4-1 (KNBC-HD). I connect straight to the wall and had to re-scan to get 4-1 back. Since they are moving things, why can't they move problematic 2-1 to a better frequency?
post #7238 of 7240
Same here. I had to bounce the TA again to fix this.
post #7239 of 7240
I agree in the CBS-HD. Nothing but trouble for that channel, and I've had Tech's out multiple times.
post #7240 of 7240
I also had to rescan to get 4-1 back on the extra TV connected with no box.
