I have a question that I did not see answered in the FAQ. I have a Philips 985 recorder and have been copying movies from my tivo. I have used both +r and +RW disks. The +R disks (Memorex and now Fuji) will record and play on my 985, but are useless on other machines. The disks have been finalized. I have tried to read them in my computer which has a + R/+rw drive, but it does not recognize the disk. I have tried them on other dvd players that are suppose to recognize the +r format according to the dvd + forumlist. The +RW will play on those other machines and computers although when you fast forward by section, you can not see the movie being played, it is just black. Do I have bad disks and can you recommend other makes, that are readily available in the US? Is this a problem with my machine? THanks for your help.
AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › newbie Question on DVD+R disks & 985
This thread is locked
AVS Top Picks
