Originally Posted by
LenL
I have the previous version the plain CM4228 with a cm 7777 preamp. IT seems to work very well for me. The CM4228HD is basically the same design. Each of us are probably in very different reception situations and so it is hard to say what works for one person will work for another. From all of my research this antenna and the 7777 preamp are high up on the list of the best of the best.
I don't think you will find too many antennas that will stay up in a tornado. Plus we are not in a tornado prone area and they are very isolated to touching down in specific streets and not a widespread event like a hurricane.
We have had some pretty good wind from thunderstorms etc and my antenna has not budged.
I must add that I have tinkered with a Gray-Hoverman GH6 home built with Narods and combined with a 7777 preamp it performs as well as the CM4228. If you are at all handy and want to try a fun project I would recommend it.
Thank you Len. Just to clarify, the plain CM4228 is
this one and the one NYC has offered me is
this one? Can anyone tell me the dimensions of the large one? I also looked into the
Channel Master CM7777 Titan2 at Solid Signal and from prior experience the 23 db VHF gain and the 26 db UHF gain on this amp would without a doubt overload my system. I cannot exceed a 17-19 db gain here. Unfortunately, I am not at all handy enough to build my own antenna. I'm real good at setting up video systems indoors though.
raj2001
I'm not so sure of that. WCBS-33, usually one of my strongest signals was pretty terrible this week. I didn't have full dropouts but I had a few times where it started to tile. Everything else was as normal.
It could just be weather... I suppose?
It is very perplexing. Sunday and Monday nights I received CBS all evening without so much as a single drop-out. Last night it was popping in and out prior to 9PM, then after that it literally disappeared. As far as I could tell, there was no tropo and the weather conditions were just about identical all 3 evenings.
raj2001
I have two of the old 4228 (called the 4228A). They work very well, phased together with a Winegard SD 3700 and twin lead to eliminate balun losses. It does radiate out the back but that can be fixed by tying the screens together with tywraps.
However, the new 4228HD is a step down. The UHF reception was compromised to make the VHF reception better.
So neither of the above is the old 4228A correct? It appears that these U/V 4228's are apparently not for me, as VHF reception here is perfect, particularly because I'm receiving WKOB with a solid 90 signal strength today, the highest I've ever seen it.
raj2001
Is cablevision really adding compression to OTA signals? Have you measured this, or are you just speculating?
Not speculation. If you were here I could show you an A/B comparison. You would not only see a startling difference in the richness of the video quality, but as well you would hear the difference in the quality of the Digital Dolby sound. Like night and day!!
Will look forward to it NYC!!
