Hi,
Gonna replace an old antenna, and for a couple of years NYC outer boro VHF/UHF Antenna recommendations seem to be to get either the Winegard HD7694P or Antennacraft HBU-22.
Structurally, it looks like the HD7694P has a 75 ohm only "box", while the HBU-22 is 300 ohm native and uses an outdoor balun. The specs list the HBU-22 as having the same max width, boom 5% longer, and 2X the vertical height (corner reflector difference?), compared with the HD7694P.
(I never quite got whether the HBU-22 was given extra points because it was once - but no longer is - available at local Radio Shacks.)
Anyone with real-word experience with these models see a functional difference for the major ESB stations (RF channel range 28-44)? This would be a roof mount, 20 ft above ground, 10 miles from ESB. I'm told there was some occasional minor ghosting visible from this location in the analog days (only VHF was viewed).
Thanks for any comments.
