Originally Posted by keyboard21
If I was you. I would try the C2 and C4 and see which one is best signal and which is best in physical size. IF the C4 is too big. Then you might have to compromise.
Do not for get HD Rg6 cable. Compared to cable company coax. I got 5 points signal higher
With your issues. I think bigger is better
Your welcome.
Your welcome.
I wont forget the cable ordered it too . i think the c4 will fit fine i dont care if it looks bad i just want my football and postseason bbl. plus if an antenna with 60mile range cant help me then it wont matter and im screwed . and would have to start in with the board about installing an outdoor antenna at that point and cost ill just find the games online and hook my CPu to my TV
