AVS › AVS Forum › HDTV › Local HDTV Info and Reception › New York, NY - OTA
New York, NY - OTA - Page 571
post #17101 of 17105
none of the 114 stations I get carry more than 36 hours of data.
You don't get 114 stations, you likely can get no more than about 35-45 or so stations, at most. However, with digital broadcasting, each station can multi-cast additional sub-channels. Some operators cram as many as 10 subs of sub-par quality into a single station while most have up to two or three subs in addition to their primary channel.
post #17102 of 17105
My mistake, I meant 114 channels, off of 43 stations (not including inversion channels). I simply meant that even with that large of a number, culled between 4 markets (most all of them from 2), that like @LenL PSIP program data rarely extends more than 24 hours (if it does it is only by a few), and receiving a large number of LPTV stations, I get no PSIP guide data on those.
Edited by Theducksfan2010 - 3/14/14 at 4:08am
post #17103 of 17105
Me-TV has a good lineup of shows but I wish one of these Retro TV channels would start broadcasting "The Wild Wild West" series in NYC metro area.
post #17104 of 17105
PMCM TV LLC. still does not have a construction permit for KVNV, the Middletown Township television station. In fact, a revised application specifying minimally reduced ERP and a minimally higher antenna was recently submitted to the FCC. Both applications are still outstanding.
As most of you are aware, KJWP Wilmington, in the Philadelphia, PA. market, is also owned by PMCM TV LLC. It is therefore likely that when KVNV signs on in Manhattan, NY. to serve Middletown Township, New Jersey, its programming will be nearly identical to KJWP, given that both stations are intended to serve as primary affiliates of the Me TV Network.
But here is a heads up for those who wonder what the programming will be like. According to another discussion forum, and specifically a sub-forum which discusses television in the Philadelphia market, "Paid Programming" was observed at 6AM ET. on KJWP Wilmington. So I checked the programming listings for that market. Sure enough, a four-hour block of paid programming airs weekdays from 5AM - 9AM, Saturday from 5AM - 8AM followed by mandatory E/I programming from 8AM - 11AM, and Sunday from 6AM - 9AM followed by additional mandatory E/I programming from 9AM - 11AM. It should be noted that the block of E/I programming carried by Me TV includes a Canadian television series, Edgemont, which aired from 2001 to 2005 on CBC Television.
What this all comes down to is that when KVNV signs-on, the overwhelming majority of New York City market viewers will finally have access to the Chicago-based classic television network Me TV. It has been long-awaited. So long, in fact, that about two months ago, some overly eager individuals twice went over to the KVNV Wikipedia page and vandalized it to reflect that the station was now airing in the NYC market. Apparently they felt, "so let it be written, so let it be done" But, unlike the direct feed that is presently enjoyed by the lucky bastards hooked up to the Time Warner Cable Manhattan system, the PMCM TV local affiliates will apparently not be providing an uninterrupted 24/7 feed from the Windy City. But despite the early morning interruption, viewers should still embrace this new programming service. KVNV will, after all, provide more hours of coverage than the Bridgeport, CT. affiliate did and be available to a significantly larger viewing population.
post #17105 of 17105
I have opened 46- 3 EEE Spanish Christian broadcasting
46- 1 was running, now color bars
46- 2 I see only commercials
46- 4 color bars
