Originally posted by azhagan I have a Dish Network 6000 reciever. And when I scan for new DTV channels the baltimore channels also show up, (13, 02) But when I view them there is no signal strength. Is this happening because I live in Gaithersburg? |
First see what strength you can manage in the "Add DTV" menu. Press the menu button and then 6-1-5 to go to the screen to add the local channels.
Pick the Add DTV. Now you can enter the Digital UHF assignment for each channel manually.
52 = WMAR ABC Channel 2
59 = WBAL NBC Channel 11
38 = WJZ CBS Channel 13
46 = Fox45
42 = MPT PBS Anapolis
Those will likely be the only channels that can be detected from G'Burg. When you enter in one of the numbers above, it will take a second to pick up the signal and lock it. If you get a solid green, then you have enough strength supposedly to view it. Press Save to add the channel, give it a lable and save again.
Note: the Dish 6000 has a problem with Fox 45. Make sure that you do not have the analog Fox45 added to you lineup when adding the digtial one. You can have minor lockups. Delete analog 45 if present and then add the digital 46. Once Digital is added, you can go back and add the analog Fox45 and it should work.
Oh, you must have decent signal strength to watch the baltimore stations. You might have had enough strength to "detect" them, but you might need to improve your antenna situation to actuallyl watch them compfortably.
