Since I saw a reply about speaker break-in in a previous thread (doubting its validity) and it had been many years since I had a brand new pair of speakers, I wondered...
Well, this week I got a brand new pair of AR 215PSb's (O.K., so their not very good. I won't even explain my reasons for the purchase). I decided to see if "break-in" was real or just an auditory illusion. I couldn't have picked a better pair of speakers for the test.
Day 1
When I first hooked these up to an HK 875 pre/870 amp, I couldn't believe what I was hearing. The tweeter and woofer didn't sound as if they were "integrated". The tweeter was so harsh that I checked my ears for hemorrhage. Additionally, there was a passage on an SACD that caused the woofer to emit a sound that caused me to wonder if it had imploded. I literally could not stand to be in the room with these speakers. I turned on the tuner, left them running and went to bed. My intention was to return them and didn't expect them to improve.
Morning of Day 2
I noticed that the woofer and tweeter had disappeared and I was listening to 2 speakers - a right and a left channel. The tweeter was still harsh and the woofer was somewhat recessed, but they were definitely working together. There was a bit of detail and separation of instruments. The passage on the SACD was still very disturbing, but just sounded like a weak connection or bad wiring. I couldn't be in the room for very long, especially if the volume was not set low. I turned down the volume, left the tuner on again and found another place to be. I still intended to return them if things didn't get better than this.
Afternoon of Day 2
If I didn't increase the volume much, I could actually enjoy some things about these speakers. There seemed to be alot more detail than I'd heard in my Boston Acoustic HD5's and there was much more bass extension. And what was this? A sound-stage? Out of these little $60 boxes? But, the harshness of the tweeter...only slightly better than in the morning...but the woofer was much less recessed. I put the SACD back on and the woofer was attempting to make something musical out of that troubled passage. The speakers could be driven at enough volume to fill the room and I was certain my ears were beginning to scab over. I decided to put the CD on repeat, turned the volume to medium well, turned treble and bass up as far as they go and left. I still intended to return them if they didn't get better... Well, if I couldn't get all my shipping back or go through a big hassle.
Evening of Day 2
That SACD passage was still troublesome, but not frightening. I still wondered if there there was cheap wiring in there. The tweeter was still blaring, but not so much that it couldn't be tolerated for reasonable lengths of time. Actually, a few feet back it didn't seem so bad and was noticeably improved from the first day. Loud volume actually seemed to blend the tweeter and woofer a bit. Things were definitely looking up and I still couldn't believe the sound-stage and detail, and these seemed to be improving. But...that tweeter. It was just too bright. I returned bass and treble to the all out position and left the tuner running at low volume. I still intended to do something with these speakers. Maybe I could adjust the treble and tame them a bit. Maybe I should send them back. Maybe I'd give them to the person who was supposed to be getting the HD5's. He would probably really like them.
Just before bed Day 2
They seem just slightly smoother all the way around. The SACD at first seemed a little better, but probably not. The tweeter seemed better, but still brighter than I liked. I turned the bass and treble all the way up and left the tuner running.
(This morning) Day 3
They really do seem better as time goes on. I don't think the SACD passage will ever be right, but I can identify individual sounds now. The tweeter... Well it is just too bright for my taste and I don't like it, but it has softened alot. The sound-stage and detail continue to impress me and make the tweeter more bearable. I will end up keeping these speakers (I think) and definitely will not returned them. The person who is on my list for "free" HD5's likes bright equipment and would be thrilled with these. Maybe he'll get them. They are better than they were and in many ways an improvement over the HD5's. They might replace my Klipsch kg1's in my home theater. They have some "horn-like" qualities. On top of all that the boxes are solid and attractive. It's a tough choice. I'll give them more time and see how they do. The treble and bass are going back to full and the volume will be back at medium - just enough to fill the room but not enough to leave the room.
Now the real question:
Are they getting better or am I getting used to them? I will try to answer it this way:
I can hear some very real differences between day 1 and late day 2. I'm also confident in differences between afternoon of day 2 and this morning. I'm not positive that the tweeter has improved since last night.
I spend alot of time NOT listening to them as a (maybe feeble) attempt to remain objective. I am convinced there is a difference, but the critics would point out how unscientific this is. I have no doubt whatsoever that there is a measurable difference between when I first hooked them up and what I'm hearing now. Anything in-between I will concede as arguable, but my convictions about those differences are not as weak as I've stated. I'm just trying to remain open to correction.
My conclusion is that there definitely is a break-in period for speakers and I hope that it remains active for these speakers.
Doug
Day 1
Morning of Day 2
Afternoon of Day 2
Evening of Day 2
Doug
