On top of the HDTV there are a number of buttons. Correct sequence is
Info, Menu-OK and right side of volume (plus). Put your
3 fingers on these buttons at one time, if you did it right you will see a darker color of grey, in towards the middle.
Take your
purple button in center of remote and with what ever color you 'chose'(Blue, Green etc) push right arrow. Hit
OK button and HDTV will start doing its own diagnostic tests. One by one if alright you will see
OK in caps.
Odometer reading of hours used, go back to
Button to left. Odometer, 'again' choose right arrow and hit
OK button. Hours used will be displayed. Get out of Service Menu at 'any' time hit
clear on lower right purple button your using.
Print and
USE these instructions until it becomes second nature to you.
