Originally Posted by
mcp111
I just purchased a RCA ANT751 antenna and I am getting most Toledo stations with little trouble, except for WNWO. I have the antenna aimed directly toward the towers, and I show 100% signal for WTOL & WTVG, but only about 40-50% at best for 24. Do they broadcast at a much lower strength? Is there something else that could explain the huge difference in signal strength I'm receiving?
WNWO does operate at less than maximum power, but should still be more than strong enough for reception in BG with an outdoor antenna.
Have you checked your connections, both at the antenna and your set?
Keep in mind that the Toledo TV stations transmit from Oregon, OH - east of Toledo and immediately south of Lake Erie, and that WNWO's tower is the easternmost of that whole group. See if turning the antenna a little further to the east may help.
The problem may be in the "last kilometer" - your immediate surroundings. Could there be a building in the path from WNWO to your home?
I'm curious if you're getting WLMB (virtual channel 40 - but actually transmitting on low band VHF Channel 5 from near Jasper, MI) - I wouldn't expect that little antenna to work on lowband.
Good luck
