Originally Posted by Sirchadwick
I am in the process of upgrading my exhisting Channel Master 4257 Diamond Quantum UHF antenna to help receive the Detroit HD feeds.
Located in South Toledo, it is a pull to get these stations. I would like to ask you guys a couple of questions:
1) Are you using outdoor antennas, and if so are you able to pull these in?
(Location dependent - please identify antenna and location of your tower)
2) Are you familiar with the High Gain UHF Antennas? If so, which one would you purchase?
- Channel Master 4248
- Antenna Direct 91XG
3) Who would you recommend to perform the install?
The 4248 has 10.8 db of gain while the 91x has 16.7 db of gain. So, the 91x has a stronger "pull". the closest thing Channel master has is a 4228 that has 12 db of gain.
no idea on who could install it, but give this link a try to help you select an antenna...
http://www.antennaweb.org/aw/welcome.aspx
happy Mpeg,
Steve
What is the problem; the broadcast signature is 1080i but it STANK. Is this a BuckeyeHD problem or a WTOL Toledo problem or a CBS national problem....
