Mark,
I have not noticed changing channels to be too slugish, but BCS has had Mot boxes for awhile. So I could be use to it being that way. Also, what out for the third generation 6412 boxes (HDMI outputs) as there are a few issues with audio. I know BCS is working with Mot to resolve them. It has been a couple weeks, so I should call up my contact to see how that stands. Until then I have stuck with the 2nd gen DVI box. Which is working fine, no need to swap'em out just for a connector type.
Also found the MUTE instructions:
Program an unused button on the remote, for instance, C
-Press and hold setup until LED blinks twice
-Enter 994. LED light will blink twice
-Press setup once and do not hold it
-Enter 141
-Press the C key on the remote.
LED light will blink twice.
-The C key will now act as a mute and un-mute for the DVR converters.
VidEditor
-Enter 141
VidEditor
