JohnJr,
Combining antennas can be tricky and yield unpredictable results. It certainly won't hurt to try it but to do it correctly you'll need a splitter, which is a 3-4dB loss. In all likelihood the added gain by having two antenna's will be offset by the loss of the splitter. Also, if the signals are not in phase between the two antennas it may look like multipath to the tuner, which is obviously no good for either the analog or digital stations.
Alternately, you could try a UHF/VHF band separator/combiner, which is a filter of sorts (this device has less loss than a splitter). The way this would work is to connect the UHF only antenna to the UHF port on the UHF/VHF band separator/combiner and connect the UHF/VHF antenna to the VHF port (effectively filtering out the UHF signals from the combo antenna). The output of the device would then feed your tuner. This means you would use the VHF/UHF antenna only for VHF and the UHF only antenna for UHF frequencies. The UHF/VHF band separator/combiner has less than 1/2 dB loss, which is far less than a splitter (and a splitter has no filtering capabilities).
