I built a Radeon LE based HTPC last weekend (7.1, 4.1, xx93 drivers) by following the excellent recommendation on this forum and I am sort of already thinking about another solution for DVD... I find the timing with Li On's post very interesting.
Here is what I observed. In the Avia DVD there is a Standard Video Test->Widescreen->Resolution pattern that exhibits a small circle at the bottom right corner with alternating white and black lines at 540 lines of resolution (6.75MHz I think). I switched the HTPC to many different (custom included) resolutions (turned the BLUE and RED guns off to avoid the need for reconvergence) but never got these lines to be uniform. There was always some sort of smearing at certain horizontal intervals along this section.
A first generation DVD player Toshiba 5109, although not ideal in every way, did really shine in comparison. The lines were rock solid, sharp and perfectly uniform. That meant this player could squeeze every single bit of real resolution the DVD format is capable of.
I am not sure if people have tried this particular test on their HTPC, but I would be very interested to see if there is some experience and perhaps a solution for this (a magic resolution settings?)...
GK
GK
