AVS › AVS Forum › Video Components › Home Theater Computers › What the best custom HTPC resolution for Q1271?
post #1 of 4
What's the experiences here by 1271 owners?
post #2 of 4
HI,
I've seen others state the best resolution for a 12xx projector is 800x600. Personally I like 720x480 as this is the actual resolution of DVD's and no scaling is required.
But, I only use my 1271 for DVD's so I can't comment on good resolutions for anything else.
Good Luck,
Brian
post #3 of 4
I run mine at 1152x864 and it looks as good as HBO HD 1080i with PowerDVD.
Jack
post #4 of 4
I have a 1272, but I believe it doesn't differ that much vs. 1271.
Depending on screen size (and how you optimize it), I usually do a horizontal stripes and vertical stripes pattern. If the resolution with which that pattern is displayed can resolve the alternating stripes, then it's good enough. Try to go up in resolution until you hit the non-resolvable region.
My 1272 can resolve 1280x720 @ 72Hz, so I stick with that. YMMV. 720x480 is good as well since software DVD player won't do any scaling, so it's native, but I can still see scanlines with 480. My setting for cannot see scanlines would be around 660 or so (800x600 still can see a bit of scanlines).
Ciao.
Muljadi Budiman.
Ciao.
Muljadi Budiman
This thread is locked
