Ok, before anything, I request that if people can post mirrors for these files, then do so below, and before downloading, check if there is a mirror below and download from that, I'd rather not put any extra strains on the original 2 mirrors.
Here's what's new since the last official release (v1.32):
Ok, and you can download v1.40 beta 5 here:
Mirror 1
Mirror 2
Webmaster
www.inmatrix.com
Code:
* Entire back-end switched from the Media Player component to DirectShow. This took hours upon hours of digging through obscure microsoft documentation, samples and delphi reference. Hopefully it didn't introduce too many bugs. * Due to the new DirectShow interface, there is a spanking new right-click menu. * Due to the new DirectShow interface, you can now access the property dialog of any DirectShow filter used in rendering the file (basically useful for accessing the DivX control panel). This is accessible through the right-click menu. * Due to the new DirectShow interface, you can now set the playback aspect ratio. You can cycle through the four aspect ratio modes by pressing the "R" key, or through the right-click interface. The four modes are: 1. Fit to Window (basically manual aspect ratio). 2. Source Video 3. Fullscreen 4:3 4. Widescreen 16:9 With these settings you should be able to play anamorphic AVI/MPEG files! (not to mention fixing the aspect ratio on MPEG-1 files once and for all). * On Screen Display support. * You can now toggle the space key functionability to be either the default toggle for the Control Bar, or to the more traditional Play/Pause setting. * You can now use Alt+[Space] to toggle the control bar. * Volume support using the Home/End keys. * Slightly restructured the interface buttons. * Added a Play and Stop buttons to the main interface. * Added an option to use the "," char in the fast forward and slow motion fields. This should help people with non-english versions of windows to enter fractional numbers (maybe). * If Play is clicked and you are in fast-forward or slow-motion modes playback will continue and the play rate will be returned to a normal rate. If play rate is normal, playback will pause. This seems far more logical. * Removed the support for the non-floating control bar, frankly, it was something that should have never went in.
Mirror 1
Mirror 2
Webmaster
www.inmatrix.com
