| Mr. Poindexter, just out of curiosity, how do you know the tapes are recorded with the same exact quality it was aired if your only way of comparing it is by playing them back through the deck? Do you have another tape deck (non JVC) playing these tapes and it looks better than the JVC? |
They are always exactly the same, because the deck records the literal digital bit stream. It's not like an analog recorder, it's like a disk drive, but on tape. When you record, you are basically just sucking the literal MPEG2 stream off of the sat signal and putting it on tape. When you play it back, it is identical to what was recorded.
The reason for the difference is that when recording or watching live, most people are probably watching the RGB outputs form the DTC-100. When playing back, most people are wathing the component outputs from the JVC. Though the bit stream was literally recorded, in this case, it is being converted to analog format to send to the projector. The thing is that the JVC's conversion to analog seems to be inferior to the DTC-100's conversion to RGB.
