AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › questions on ff12r 985 (A03) new modes
post #1 of 4
I've got a 985 with ff12r firmware, and have read some good reviews of the new SP+ mode (2.5hrs).
I'm curious if the new modes or any non SP modes (I've been using 2 hr. SP mode almost exclusively, and am happy with it), have any decreased compatibility in other dvd players?
Any comments on EP mode (4hrs) in general, or the new EP+ (6 hrs!) ??
thanks.
post #2 of 4
As to compatibility with other players, the DVD+R/+RW format is the most compatible there is. I also record to DVD-R/-RW, and have a total of six DVD players, only the Pioneer which creates the DVD-R/-RW can play back those recorded in excess of 2 hours, although all players can play back DVD+R/+RW discs recorded at any speed.
In my own experience (I've recorded well over 400 discs using both formats), recording in excess of 3-1/2 hours yields poor video results. Six hour recordings are worse than standard VHS tapes, and 4 hours recordings are not much better. I run the progressive output of the DVD players through a scaler for 1080i going into an HDTV. Even going straight SVHS to SVHS looks really poor at "extended" play speeds.
post #3 of 4
thanks dr john for the good info. i'll keep that compatibility info in mind, and will let you know if i end up trying an EP 4 hr test disc on the 985.
on your other topic, I've had HDTV and progressive scan players for a few years, and although this will sound odd, a very good non-progressive scan, component output dvd player (e.g. panasaonic a-7), can look qualitatively better than the component outs of an early first gen progressive scan dvd player (e.g. toshiba 5109), IF the tv has a good line doubler.
Of course the 5109 had some now known issues, but you may want to try both outputs if your set's line doubling is exceptionally good.
post #4 of 4
Apparently not.
  Back to Forum: DVD Recorders (Standard Def)
This thread is locked
