I'm so glad I found this thread! I have a VR-407 that is about 5 years old. I don't think the remote ever worked right. As many of you have said, it works for the first five minutes then stops working. It sometimes starts working again after awhile then stops working again. After reading the thread, I decided to tackle the job. If I screwed up, what the hell, I could buy a new state of the art receiver.
I had never soldered before so I read the various recommended sites and went out and bought an inexpensive soldering iron from Lowes. After procrastinating for a few days I finally cracked it open. I wasn't sure if I was supposed to take the front panel off or just the circuit board. Since I couldn't get to the screws very easily on the board I opted to take off the front panel. I disconnected the top and right side ribbon wires, the head phone wire, and a couple of others. The front panel flopped down after I unscrewed it. One longer wire on the right side was still connected.
I had the photo printed from Chinadog's post and with that tried to find the three connections for the remote. It didn't match up though. I found another photo of a VR-409 that was an exact match to my board. I thought I had read in one of the previous posts or on a recommended website to try and just melt the existing solder instead of adding new solder so that's what I did. I then put it back together having just a little difficulty with the top ribbon. It's very flimsy and hard to plug back in without buckling.
It's been working for 2 days now so far so good. Thanks to everyone here who figured out the fix. You saved me from having to buy a new receiver. With the remote fixed it feels like I already have a new receiver!
