AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Panasonic E80 owners please reply
post #1 of 7
For those that have this unit, can the HD be replaced with a bigger hard drive?
Can it be used on the computer as well???
post #2 of 7
no and no
post #3 of 7
Can we do 1 to 1 switch of the internal 80g harddisk ?
post #4 of 7
Yes. When you put in a virgin hard-drive, it'll ask you to format it. Anyway, that's what I recall from HS2 hard drive discussions some time back.
post #5 of 7
Allright, lets get speculative.
How about if you have a friend with an E100. Remove his hard drive, put a new one in to get it formatted, then put it in your E80?
post #6 of 7
Your E80 will reformat it -- it'll then show & record only 80GB worth, not 120GB worth.
What we need is a new firmware that tells the E80 that a larger HDD is installed. But, we need a real techie who can extract the E80's firmware & modify it.
post #7 of 7
Really? I would think it would recognize the file structure and think it didn't need to.
  Back to Forum: DVD Recorders (Standard Def)
This thread is locked
