AVS › AVS Forum › Video Components › Home Theater Computers › DScaler 2.3 and CPU usage
post #1 of 2
I'm trying DScaler for the first time. PC Specs as follows: P4 1.4 GHz, 256MB, SBLive Value, Herc GeForce2 MX (Det 12.10), and Win-TV Go. The problem I'm experiencing (on DTV 2.1.2 and DScaler 2.3, I haven't tried the older versions) is that my CPU usage stays at 99%. I've tried as many settings as I feel safe trying. The program works perfect in EVERY way except for processor usage. Win-TV's application runs at 0%-1% usage. Any help would be great.
post #2 of 2
everettes -
Depending upon settings DScaler will try to grab all unused CPU time. It looks bad on a CPU monitor but it will gracefully yield if anything else is running.
Since you have more than enough processor power anyway you can easily change this behavior by adding a line
Sleep_Interval=1
to the [Threads] section of the DScaler.ini file.
- Tom
Getting started:
HTPC FAQ , DScaler , Xcel's Links .
This thread is locked
