AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › DVD recorder with progressive inputs?
post #1 of 8
Are there any DVD recorders with progressive inputs on the market?
post #2 of 8
Yes, the wonderful Philips recorders have this capability. Unfortunately they lack a hard drive feature and also, apparently, quality control. Frankly, IMHO, component inputs are an overrated feature in a consumer level DVD recorder (playback is a different matter) vs. using S-video or even in some cases composite inputs. People seem to be quite happy with the Panasonic recorder line which lacks any model that uses component inputs.
post #3 of 8
Vferrari, which model will let you record 480p? I understood them to only record 480i from the component inputs.
post #4 of 8
Yes, that is what I have found. No 480p recording.
post #5 of 8
My bad. Misread progressive in as component in. Probably need more sleep.
post #6 of 8
The new recorder from Philips supposedly writes 480P. This is a new model with a new feature.
post #7 of 8
Which Philips model are you refering?
post #8 of 8
ttt
  Back to Forum: DVD Recorders (Standard Def)
This thread is locked
