Originally posted by Rockin'EZ
Chlamydia,
I am having the same problem.
I am also getting the "Video not found" error every time a program ends.
I have to go back into setup and re-select the video input.
The thing forgets the input and records hours of blank video. Very frustrating.
I love my ReplayTV, but in the 2 months I have had it, it appears buggy as all get out. I had great luck with it for the first 3 weeks. Since then it has been a strugle.
Folks - Are these things stable?
What is the video input? If it's a cable or satellite box, you'll have to make sure that that isn't the problem. Do you have a VCR that you can hook up to another set of outputs from the converter box?
If that's not it, you might want to try a new hard drive. If it worked fine for a few weeks and then got worse, that sounds like the HD. But if you bought it from DNNA, you would invalidate the warranty by opening it. If you bought it on eBay, you might not be covered by the warranty and your best shot might be a new HD.
FWIW, I've had mine for 10 and 7 months, respectively, and other than occasional reboots when my wireless network hangs, I've had zero problems with the hardware and software. (Most of my problems stem from crappy guide data from DNNA.)
