AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › More New Replay 5000 Software Toys!
More New Replay 5000 Software Toys! - Page 6
post #151 of 156
Originally posted by bunsen
This is my first attempt at using RTConvert, and I keep getting this error:
audio buffer overflow: len=66809
Here are the audio specs for my source file:
Audio : 10.12 MB, 224 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
What's wrong?
This is an old thread.
There is an updated version of the rtvTools you are trying to use including rtvConvert here:
http://www.avsforum.com/avs-vb/showt...hreadid=314017
Try downloading the newer version of the software.
If you still have problems, ask about them in the newer thread listed above.
Welcome to AVS Forums.
(No I don't work here)
cow
post #152 of 156
Thanks. I got to this thread from the ReplayFAQ.com main page.
post #153 of 156
I have read this thread and decided to try extracting some programs from my Showstopper using the extract_rtv program and attempt to play them back through my 5040 using the DVArchive tool. I can get the mpg file into DVArchive and I can play the file on my PC, but it does not show up in the guide on the 5040. I can see other programs in DVArchive in the 5040's guide. Does anyone have any ideas why I can not see the program in the 5040's Guide?
post #154 of 156
There is a more current thread on this topic here:
http://www.avsforum.com/avs-vb/show...threadid=314017
Better to reply to this post there.
Did you 'import' the shows into DVA?
cow
post #155 of 156
icecow
Your link to the more current thread comes back page not found???
and yes I imported the show into DVA
post #156 of 156
I believe icecow was trying to refer you to the following thread.
ReplayTV 5K Tools (Revision 4)
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
