Just so we're all on the same page, here's the background:
DVI on Sony 2002 vs 2003
Vertical bar on Sonys when viewing 1080i
DRC modes on Sony sets
So SONY 4:3s only scan HD in their 16:9 area?
And here's the latest from the last link:
| Originally posted by montreal Even though my question is treated in two other threads, I raised the question here because DWE referred above to a MID3 type parameter and I hoped he also knew about this mysterious MID1 DPSW parameter. Sorry to go off on a tangent. Adu, you can only get a scrolling bar by having the incoming 1080i signal present. My suspicion relates to what you have mentioned in your other thread about the difference between 2002 and 2003 where some circuits are bypassed for better PQ. By chance, the solution to stopping the scrolling bar on 2002 models is also to completely bypass the circuit which up-converts 720p, and 1080i to 1080.0001i, for lack of a better name. Without the patch activated bypass circuit, I wondered if 480i and 480p were also being up-converted as well, maybe both to 1080.0001i? The scrolling bar is due to the difference between 1080i and 1080.0001i, roughly one hertz. When bypassing the up-conversion circuit which is only reasonable for 480p and 1080i (480i and 720p both need up-conversion), you also eliminate using the two redundant a/d and d/a conversions for a better PQ. To know that the bypass is working, one has to have over 2 volts present across pin 5/6 of connector CN3203 of the B board (TH CONTROL). This is the signal that turns on the bypass circuit. If it fails to ever turn on with the HDPT patch (I assume it always does when required), then I was wondering if the MID1 DPSW patch increased the chance that it would turn on. This second patch (DPSW) was specified for the XBR2 but not the HS500/XBR800 and I assume that the HA3 chassis may have more privileges than the DA4 chassis since their owners paid more money for the former. Also the TH CONTROL signal comes directly from the delicate main CPU chip outputting a MOS level signal. In a month or two I plan on measuring the presence of my TH CONTROL signal when playing a 480p or 1080i source. I may even attach a buffered LED pilot light to come on when the signal is present. |
| Originally posted by montreal HDPT is under category OP. As for whether 480i and 480p are up-converted to 1080i? We know that without the HDPT patch, every input signal must go through the conversion circuit. 1080i is up-converted to 1080.0001i causing the scrolling bar, and 720p is up-converted to 1080.0001i and 480i and 480p are up-converted to something. The reason I add .0001 to the format is that we can't be sure that the horizontal frequency coming out of the converter is a precise copy or multiple of the source frequency. It is internally generated from an independent source. So the question is if 480p goes into the up-converter, does it come out of it as 480.0001p or 960.0001i or 1080.0001i? All would look about the same because the converter does a good job. And would 480i come out of the converter as 960.0001i or 1080.0001i? Switching on the bypass circuit for 480p and 1080i input signals allows the horizontal scanning rate to lock onto the incoming signal and completely eliminate any slow or fast scrolling vertical bar. My guess is that all formats (480i,480p,720p, and 1080i) come out of the converter at 1080.0001i. The 1080.0001 timing is subdivided from a fixed crystal oscillator and it would be the one and only native scanning rate for the TV. You would need a oscilloscope to see it or hold a transistor AM radio near the back of the TV and tune it between stations and listen if the whining sound changes pitch when changing inputs from 1080i to 480i to 480p. In other parts of the world, multiple formats may all get up-converted to one fixed internal clock generated scan rate as well. Perhaps in other countries the scan rates of the input signals are never very close to the TV's native scan rate so that the vertical bar scrolls too fast to be noticed. In North America, Sony made the mistake of choosing a native scan rate too close to the up-converted scan rate ( a 1 hertz difference). |
