AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › DVD-R disks can screw up your DVD player.
post #1 of 3
Before any of you geniuses make snide remarks about this being impossible, I am here to tell you that occasionally when I play DVD's recorded by my Panny DMR-E30 that it will cause my Sony S9000ES DVD player to freeze, skip and otherwise behave badly when subsequently playing a commercially recorded DVD.
There is no doubt after months of observations that the ONLY TIME there is a problem with the Sony S9000ES DVD is when playing a commercially recorded DVD AFTER playing the DVD-R.
The good news?
So far, by completely powering down (unplugging) the Sony DVD player for a couple of minutes, it will apparently reset itself and work perfectly until the next time a DVD-R is played.
For all the fine contributors that mocked my original post about this many months ago... may a power surge pop your new amp.
post #2 of 3
The good news?
Yup, this is definately true. Usually is a case of a slightly misauthored DVD-R disc semi-crashing the player's firmware. I was nearly convinced that my Rowa DVD-3610 was incapable of playing DVD-Rs, but after finding a commercial DVD had the same problems, I powercycled it. I found that the first DVD-R I had ever tried would crash the player, the other DVD-Rs that previously wouldn't play at all played fine as long as I had powercycled the player since that first disc.
post #3 of 3
Entropy512.
Thanks for your fine post. Would you mind posting your reply in the thread of the same title over in 'DVD Players' where there is an ongoing conversation over there. I shouldn't have posted in two forums.
  Back to Forum: DVD Recorders (Standard Def)
This thread is locked
