I prefer optical/toslink. In addition to the possibility of a ground loop hum, I've also had problems with coax, where I'd get an audio dropout when the light in the kitchen was turned on/off. Plus, there's the fact that some soundcards supposedly send an out-of-spec voltage on coax. Coax digital can also sometimes be susceptible to interference.
The only downside to Toslink is that the cables might be a little more fragile, but I think if you're even remotely careful this should be a problem at all. I've certainly never broken one.
Toslink cables might be a little more expensive, but if you go with the RadioShack brand cost shouldn't be too bad for short runs.
Jeff Kohn
http://home.houston.rr.com/jeffkohn
My DVD Profiler Collection
[This message has been edited by JKohn (edited 06-10-2001).]
Jeff Kohn
