AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Panny DMR-E50 Question
post #1 of 5
Hi All. Is it possible to hook up my Pioneer DVD juke to the E50 and play DVD's through the unit to get progressive scan to my HDTV?
John
post #2 of 5
No it accepts interlaced component video input only, not progressive.
post #3 of 5
Well, The component outs on my jukebox are interlaced only. What I am trying to do is hook it up to the E50 and then use the E50's progressive output. Will it work this way? Sorry for newbie question!
John
post #4 of 5
The E50 only has s-video and composite inputs, there is no component in, only an output.
post #5 of 5
So you are talking about the output not the input, correct? I am in the same boat if anyone has had any experience with this. Can I feed a non-progressive scan DVD player through the panny E50 and have it output progressive to my HDTV?
  Back to Forum: DVD Recorders (Standard Def)
This thread is locked
