You should be ok if your e2500 has been configured to provide routing/firewall/wifi security for your internal network. Presumably, your motorola has already been provisioned for bridge mode operation. Verify that your e2500 has an external, routable, ip address.Originally Posted by DNINE
Do I have to worry about the Motorola if I am not using it for wireless? I'm using my Cisco e2500 plugged directly into the
Motorola which has it's own encryption.
Should I do the same workaround #2
I don't know how reliable the speed test are- with the RCA I was getting ~20mbps down 1mbps up. The same tests show 10 and 1.
Speedtest - you might want to try the local TWC site and report back: http://speedtest.nyc.rr.com/
-nony
Edited by nony - 11/13/12 at 8:03am
