AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › A better grey screen
A better grey screen - Page 20
post #571 of 918
riekl using melamine like cappra has used is a couple of steps easier than mdf it saves priming and gives a good base to paint whatever paint you want, that is what i used on my main screen but they have a pretty smooth surface so before your first coat just give it a little scuff or use liquid sandpaper it helps to dull shinny surfaces for your paint to adhere to
Bruce
post #572 of 918
CMRA,
Is ME two coats of Misty Evening over top of two coats of Kilz primer?
Do you wet sand between coats leaving the final coat very smooth?
Thanks for your help.
I think ME will be a GREAT DIY starter screen.
Dobber
post #573 of 918
Dobber-
Yep, that's the basic ME screen. Kilz2 to prime, then 2-3 coats of ME on top. Wet-sanding is not necessary, but it will definitely help matters when viewing HDTV and high-quality DVDs.
post #574 of 918
Thanks, scoob5555.
I spent 90% of my HT budget on the projector (Z2) so a cost effective, DIY screen solution became mandatory. CMRA's screen shots are what convinced me to try ME.
Dobber
post #575 of 918
Originally posted by Dobber2
CMRA,
Dobber
In the beginning...
Specifically, I used 2 coats of kilz 2 white pigmented latex primer followed by two coats of ME. No sanding was required. Others have opted with favorable results.
Just so there is NO misunderstanding, this is the ME you want:
http://www.avsforum.com/avs-vb/showt...64#post2719264
It looks like this:
http://www.avsforum.com/avs-vb/showt...69#post2716869
best wishes.
post #576 of 918
Thanks, CMRA. I printed out the picture of the can lid and I will verify that is what I bought. Thanks for all of your contributions to these forums. You and others like you, have saved me and others like me, years of research on HT. Keep up the good work.
Dobber
post #577 of 918
Dobber
Dobber,
While you are at it, your ME at the ready and all, there's talk about adding pearl-essence to the ME mix. One person mentioned using it as a topcoat another mixing it with ME. While your'e making your screen, would you give this some consideration and report back your findings to all. ( a couple of smaller test panels will do) Thanks, CMRA
post #578 of 918
Originally posted by riekl
P.s. Thank you all so much for your dedication and hardwork you likely just saved me about $1000 on a HCCV screen/frame.
Forgot to respond. Thanks for the kind words. That's pretty much how I looked at it too. Awhile back, another member took down his Grayhawk in favor of the ME. Never will forget that. Best wishes.
post #579 of 918
H E L P...
I have a Z1 - I'm very excited about painting my screen (artist canvas) in ME.
Question: must you use the Masonry and Stucco Latex. HD in my area has the ME color, but not in the Masonry and Stucco.
post #580 of 918
Just use exterior latex
The masonary thing was simply due to the original coating coming from leftover masonary paint that 'cheap 'ol CMRA had left over. You sure DO NOT want excessive texture. In fact, the smoother the better.
Ya know, it could have been lemon yellow if the odds had played out differently.
Talk about a 'pissin' contest over DIY screens!
post #581 of 918
Hey MM,
I could go back 29 pages and loose my eyes and patience, but...what have you done with your screen?
Thx
post #582 of 918
Originally posted by RichBoss
Hey MM,
Thx
Rich,
You'll find MM's latest endeavors here:
http://www.avsforum.com/avs-vb/showt...hreadid=362890
post #583 of 918
I've been up to my knees fending off gators, but I did make it to Home Depot and got more pearl-essence...the last jar of white opal on their shelf. Hopefully, I'll get a breather by Thursday and have an ME/Pearl first hand report to share. Do I dare just shoot a coat of opal atop my ME screen? Or a 50/50 mix?
post #584 of 918
First report: Single coat of white opal atop ME not enough to make a difference.
Test two: Two and three coats of white opal on top of ME. (coming)
Test three: 50/50 mix ME with white opal. (coming)
post #585 of 918
Two coats introduced to much sheen, hence potential hotspotting. The overcoat appears to be a no go. The 50/50 mix should be projector ready today.
post #586 of 918
The 50/50 holds promise. Watch out! Today, I plan to mock up a 75/25 panel for testing. Side by side too. Screenshots?
post #587 of 918
I searched this thread and can not find a review of a DLP with this ME screen.
I have a 240K and I am interested in reducing the greenish tint in my blacks, making them seem deeper. What is the consensus?
post #588 of 918
Just an FYI ! I put my 2 coats of ME on my blackout cloth DIY frame last weekend and it did exactly what I wanted ! My projector is an HS20 the blacks still aren't black as a crt which I didnt expect them to be but some day !
anyway very happy with good ol' ME don't think i will be experimenting much more on this level happy with this solution, thanks for all your hard work CMRA !
post #589 of 918
Well, I could not wait, I went out to HD and got the ME grey but not in the same base as mentioned. They did not have masonary base. I guess I will see tonight if it made a difference on my Da-lite matte white screen..
post #590 of 918
To sheen or not to sheen. As previously mentioned, two coats of WO atop ME is a no-go. Way to much sheen and notable hotspotting. One coat, after curing actually became more desirable than the 50/50 mix. The jury is still out on the 75/25 mix.
I can see Rahu's excitement in a way. But as always, you don't get something for nothing.
Back down to the dungeon to work on 'Black Pearl'.
post #591 of 918
CMRA - keep the goods coming!!! all your grey DIY is certainly appreciated. i have a gallon of ME, some White Opal and am just waiting eagerly for tomorrow to start it up...
post #592 of 918
I watched LOTR last night on the new ME screen. I suppose it is better. I have nothing to compare it to. I wish I could be more comprehensive.
Has anyone used a FL-D with a Grey screen?
post #593 of 918
What ever you do, save some WO and mix in some lamp black colorant and give that a whirl. I'm in the process of trying that on a mirror. I wouldn't mind some feedback from others. Another attempt is the same with some pigmented primer added. I'm calling it 'Black Pearl' and 'BP Lite'.
post #594 of 918
What do you do with all that left over SM? Mix it with white pigmented primer, that's what. Talk about quick and easy. ANd it works in light fusion applications also. Mix thoroughly.
PS: It looks grey too.
post #595 of 918
it's all good. after much ado and mixing all kinds of ME/ME lite/ME WO etc etc. I went with a kind of ME slightly lite mixed with WO. couldn't be happier. DLP projector gets much better blacks/blues and haven't lost much on the bright side of things. after callibration I am totally set on the cheapest screen possible, just paint the wall, that's all. THANKS CMRA! and all others on the grey side of life.
post #596 of 918
Ok...but, how are you dealing with the wall texture? Also, will you boarder your screen? Good viewing and best wishes, CMRA.
post #597 of 918
CMRA, Have you made any observations with the WO/Black combo either on a mirror or on a wall?
post #598 of 918
INFO: I painted my Da-lite matte white screen. It curled on the outer edges.
last post here
post #599 of 918
CMRA - after several coats, the wall's texture has become kind of a non issue for me. my old plaster walls were pretty smooth to begin with, i'll live. border complete with black felt wrapped around and glued to 3" thin posterboard. this, gasp, i tacked to the wall with staples. can post a pick if you'd like...cheapo city!
post #600 of 918
"can post a pick if you'd like...cheapo city!"
Picks, nothing! It's time for screen shots!
Yes, I/we would love to see your handywork. Snap away.
  Back to Forum: DIY Screen Section
