Originally posted by caseyathompson
Anybody hear anything about WNNE? It was supposed to go into testing, but I don't have an HD STB yet to check it out.
Casey,
This is latest I've heard from WNNE:
"Walt,
Good to get some feed back, I was at the mall the other day and
asked the salesperson about DTV and they had no clue that there was such a
thing as over the air DTV! I guess that will change as more of us convet
to digital and promote that fact.
Just curious as to what type of antenna you are using? set top or outdoor?
Wondering if you have had any issues with cars/ people moving around
causing reception problems?
We are planning to pass NBC HD when HD programming is available, and WNNE
upconverted NTSC when it is not.
Have not heard of other stations in the group having any aspect problems,
but thanks for the heads up.
We have the antenna mounted, line run , tested the line and antenna with
manufacturer on tuesday/ wed .
Scheduled to have transmitter manf. up first part of december to do
install. Not sure when we will be transmitting full time.
I will let you know, but keep in touch.
Have a good Thanksgiving,
Roger"
I usually run a signal check for channel 25 a couple time a week with my Dish 811 but nothing so far. I get a 90% signal from the VtPBS-HD off of Mt Ascutney, so WNNE should come in great when it happens.
WaltinVt
