Originally Posted by Bert003
Does anybody know at which phantom voltage the DD-12's microphone operates? I mostly can't see any eq-curve with the sweep tones anymore. Only if I put the mic. 1" away from the woofer at subwoofer volume >30, I can see the curve.
But at normal listening distance there is no eq-curve at all. If I measure the DC Voltage with a voltmeter between 2 pins in the XLR-plug it
shows 11,7V. Is this normal? I tried another Velodyne microphone so it isn't the microphone or cable.
Also, when the volume level indicator is set at 30 without input signal, the woofer is a bit nervous, I can feel it moves as if there is some internal noise which gets higher with the volume. At volume 30 it is also a bit hearable. No real problem because the normal operating volume is 5-10 and then you can't hear it. Is there any circuit in the sub to eliminate noise from the mains outlet? Should external filters be used when the 220V has to be cleaned?
I am a new owner of this used woofer.
Hello
The EQ curve should appear once you enter setup (1 2 3 4 5.) Can you hear the sweep tones? In the upper right corner of the screen do you see "MIC?" If so verify that the cable is plugged into the bottom XLR input. Also try increasing the volume to the signal.
Yes, there is circuitry in the DD amp to prevent AC noise. With nothing connected to the DD12 but AC power can the noise be heard from over 5ft. away? If not, then the unit is working correctly. Yes, external filiters should be used when the 220V needs to be cleaned.
