Originally Posted by Rob Morse
It is odd to see a unit work when tested, then not work after an airplane ride. Using the iPod and connecting directly to the RCA inputs is a good test, provided the iPod volume is set between 3/4 to full volume. If with music that has heavy bass, you are getting no output then it seems there is a problem with the subwoofer. Unfortunately you will need to contact the Singapore distributor from which you purchased the unit for warranty service.
Thanks for your reply... really appreciate it.
However, is there anything that I can do first to make it works before send it over back to singapore..coz it really cost a lot..
about $220.....(half of my velodyne sub's price
Does velodyne cover the shipping?
