I don't think this is a widespread problem, but I've seen a few posts about Sync issues with various inputs and code levels on the X1. I thought it might be helpful to bring the people that are having issues together in one place to compare notes and make InFocus aware of any remaining problems.
If there is a pattern to it or some repeatable problems, then that information should be helpful to InFocus.
So if you are having Sync issues (the X1 goes to blue screen and has to reacquire the signal), please post what the input source is (make/model/connection), what firmware version the X1 is running, what seems to trigger it, and if it is repeatable.
For example: Losing sync with my JVC DVD player model xxxnnn running 480p progressive to the VGA port. My X1 is running 4.1 code and I have tried both the Sync option settings that were introduced in 4.1. It seems to happen when there is a scene that is all or mostly white. For example, it always happens at x minutes into chapter x of Lord of the Rings, when the sword flashes. I have the same problem with version 3.8 but it works fine with 3.6.
Edited March 18, 2004:
InFocus has released a new firmware version that is supposed to address the Sync issues.
For X1: version 4.3
http://www.infocus.com/service/x1/x1...=1&soft=system
For SP4800: version 1.6
http://www.infocus.com/service/sp480...=1&soft=system
Try it and please report back in this thread whether it solved any problems for you or not, thanks.
For X1: version 4.3
