Originally Posted by
CaCHooKa Man
I'm getting an HDTV within a week and I only have standard cable from TWC. If I were to upgrade to digital cable, would I only need to add a HD receiver for the 1 HDTV and keep using the normal cables I have connected to the rest of my TVs? We have 10 TVs in total connected to the cable and it would be very expensive to have a receiver for each of them.
This would be dictated by the type of TV you are buying. If the TV you purchase will have a QAM tuner then you'll be able to tune all of the digital channels and the free HD channels from TWC
without any sort of a box or even a cable card.
The free HD channels that TWC offers at the moment are CBS, NBC, CW, ABC, KCAL, Fox, my13, KCET, KCOP and FSN West.
I suggest to you that once you decide on the make and model of the television you plan on purchasing that you search for it here on avsforum. Not only will it help you make a better choice it will also be very educational. Highly recommended.
Good Luck.
Rudy
