AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Los Angeles, CA - TWC
Los Angeles, CA - TWC - Page 278
post #8311 of 8808
Hmm... what about this: http://www.urcsupport.com/images/uploaded_images/Atlas_1056BC.swf
double button on left side of circle labeled DAY.
If this doesn't work, then there is supposedly some way to key in codes that are not on the remote. This is either in the users manual or in some Wiki on the remote somewhere. DAY works on my DVR (3416). Hopefully these codes are still recognized by the 3400.
3. You can change the recording to stop at a later time when setting the recording, but I don't recall an early start time. I also don't think there is a global time extension for all recordings.
post #8312 of 8808
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Programming_the_Remote says "Key remapping is not available on Universal Electronics' 1056B03 remote." I don't remember those day buttons. I am not there to check again right now.
I need to take a picture of it for you guys. I can't find a clear big photo online.
post #8313 of 8808
I have that remote (in the link you listed) and the DAY works with my 3400.
But, you can't remap keys or add the skip fw hack to this new remote. You have to get the older 1056B01 remote to remap keys or add the skip forward hack>> http://www.emtcompany.com/time-warner-1056b01-remote-control/1000975.html
That remote will work with the 3400.
post #8314 of 8808
Originally Posted by phildaant View Post
Let's start with DVR's RC (1056B03 under it -- http://www.urcsupport.com -- can't find a big photograph to show all the buttons clearly for you) since it is not the same as shown in that PDF. There are no day+ and day- buttons I can find to skip days in its TV Guide. I even tried pressing buttons that sort of match like in the pictures, but nope!
I have the 1056B03 remote now and it has the 'DAY' rocker button on the upper left side (as in the link pic phildaant posted) and it works (pages through the days) on my 3400.
But again, you won't be able to remap with this remote, nor add the skip forward hack, you need to buy the B01 remote in the link I listed to do that.
post #8315 of 8808
OK, I see them now. I will mess with them later.
Seriously?!?!? How lame. I can't even fast forward? What else does this dumb RC can't do?
Does TWC have another RC to replace with that can, or do I really have to get my own for my new six days old Motorola DVR DCX3400 with its old iGuide?
Edited by phildaant - 8/11/12 at 11:31am
post #8316 of 8808
you can fast foward you just can't program the 30 second skip trick. pressing the right arrow next to the ok/select button will fast forward or you can use the fast forward button on the remote to do you what you want smile.gif
post #8317 of 8808
Oh, so it will be like a VCR then.
post #8318 of 8808
No 30 second skip forward, but you can fast forward as mentioned and you can skip 5 min forward.
You have to get the B01 remote to program the 30 skip forward, there is no other way. TWC probably has a bunch of old ones laying around, but getting one from the office could be an ordeal ('cos they probably don't know what to look for).
The for sure way is to buy one yourself for $15, that's the cheapest solution unfortunately (unless you get lucky at a TWC office, etc.)
post #8319 of 8808
STB UPDATE ALERT - TWC SOUTH BAY
I just got a PARTIAL message from the TWC bot that my STB is being updated and will be out of service for up to 40 minutes.
Ordinarily this wouldn't worry me, but
a) it is the first message I've ever received,
b) I'm a non-DVR (4250HDC) subscriber that TWC has no respect for, but most importantly
c) THE UPDATE DATE AND TIME AT THE MSG BEGINNING WERE CUT OFF!
Anyone else get this message?
If I find out more I'll post ......
TIA, Mike
post #8320 of 8808
Just setup my Centronics ZAT502 w/ QAM, I'm in the Miracle Mile area (Mid-Wilshire). The virtual channels are really odd, as in 66.22 for KLOS, 66.25 for PBS, and NBC HD is 67.541!
I figured that TWC moves those around and they might not be identical to the analog and OTA channels, but seriously, 67.541 instead of 4.1?
Is there a table somewhere that lists them? Because I have no plans to memorize those numbers, not to mention my poor gf...
post #8321 of 8808
I've seen some folks try to maintain one, but it is a never ending chase. TWC apparently doesn't care about Broadcast Basic customers with direct connected digital televisions, only about STB using customers. mad.gif
Same thing happens in Comcraptic territory where my mom lives and I made a channel list for her. Every Single Visit requires an update. BTW TV rescanning 'fixed' most of the issues last time - the LG HDTV 'virtual' channel number stayed the same but the (unknown) RF QAM channel apparently changed. On this TV the virtual channel numbers now mostly match the OTA channel numbers. Other Comcast note - her Motorola STB has been stable, the DTAs not so much.
On another TWC note, my non-DVR STB (4250HDC) got updated early this AM to ODN version 5.2.0_9 - the famous 'black guide'. So far all is better. It is now possible to exclude non-Favorite channels from the program guide (similar to previous grouping feature).
post #8322 of 8808
Just received a notice today that C-SPAN, KWHY, KBEH, WGN America, Golf Channel, and CNBC will be digital only. That means 1 free standard-definition box until November 2013. After that, the freebie box will be 99 cents a month.
post #8323 of 8808
I hope this reclaimed bandwidth will be used for more HD channels!
BTW, to tell TWC what HD channels you want that they don't currently carry in L.A., go to https://www.timewarnercable.com/SoCal/about/contactus.ashx; expand "Email Us" (the last one down), and in the drop-down menu (under "What is your question about?") select "Channel Suggestions"; then list what channel(s) you'd like to see in HD. The more requests they get for HD channels, the more likely it is that they'll add them to the lineup, assuming both that bandwidth permits and that TWC can come to an agreement with the programmer(s) to add the channel(s) you request.
I think you mean KLCS. KLOS is a classic rock station on 95.5 FM.
post #8324 of 8808
Anyone else having Internet connection problems in the Los Feliz (Eagle Rock) area?
post #8325 of 8808
Try posting in http://www.dslreports.com/forum/cable,rr (might need to share your cable modem status from its http://192.168.100.1/ ) and checking http://help.rr.com/AA/rrwho.aspx?resetDiv=true&ReturnUrl=%2fHMSLogic%2fnetwork_status.aspx ...
post #8326 of 8808
post #8327 of 8808
Cool. Just remember where to go if you need TWC's Internet support. wink.gif
post #8328 of 8808
post #8329 of 8808
Also, note that they have private direct support to TWC through DSL/Broand Reports' forums too.
Edited by phildaant - 8/14/12 at 4:42pm
post #8330 of 8808
I just discovered that my SA8300HD's menus are now black. I had no idea this was coming. It's actually easier on the eyes now wink.gif
post #8331 of 8808
You guys should hang out in http://www.dslreports.com/forum/r27236010-Time-Warner-Cable-starts-rolling-out-lightly-refreshed-guide as well. They were talking about roll outs before they happened. wink.gif
post #8332 of 8808
TW's website is now has the Pac12 Network channel numbers.
245 Pac12 LA - SD, Basic Cable
246 Pac12 NAT - SD, Sports Tier
369 PAC12 NAT - HD, Sports Tier
370 PAC12 LA - HD, Basic Cable
So it looks like Pac12 LA will be available to everybody who has digital cable.
post #8333 of 8808
post #8334 of 8808
Also it seems that TWC launched KWHY HD in Socal as well on channel 390.
The former Comcast areas have all of those channels so they just gained 3 HD channels so they have some room to add more HD. Anyone in a former comcast area want to do a QAM scan and see where they put KWHY HD? curious to see where they put it on those systems biggrin.gif
post #8335 of 8808
Obviously not all USC games will be shown there since the Pac12 still recently signed big contracts with ESPN/ABC and Fox. Maybe not even most, but we shall see. Here are the Pac12 Network schedules:
Pac12 LA Schedule
http://www.pac-12.org/portals/7/images/programming-schedules/losangeles.pdf
Pac12 National Schedule
http://www.pac-12.org/portals/7/images/programming-schedules/network.pdf
post #8336 of 8808
Pac12 LA Schedule
Both links show "404 - File or directory not found. The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable." error. frown.gif
post #8337 of 8808
Sites sometimes do not work temporarily. That happens on the Internet. Anyway, the Pac12 Network's website is:
http://pac-12.com/
You can get additional info there. You can also watch a stream of the channel there provided you authenticate first. I don't know about you guys, but those live double headers of non-revenue sports is sure getting me excited.rolleyes.gif
post #8338 of 8808
http://pac-12.com/
post #8339 of 8808
Anyone notice the sound on PAC 12 LA HD (channel 370) coming and going throughout today (the picture is unaffected)? Weirdly enough, the sound on the SD version on channel 245 is normal. I have the City of Los Angeles lineup, and I'm on the Santa Monica headend. Is this affecting other areas? As of this posting, it's still doing that where I live.
post #8340 of 8808
Hi all!
OK, I have a dilemma on my new Motorola DCX3400 DVR with TWC starting in October 2012 and was wondering if there is a way to fix this for cheap or work around it. I have many TV shows on Sunday nights starting in October 2012 at 9:00 PM PDT for an hour (really wished MythBusters went back to its Wednesdays):
9/30 9:00 PM - 9:30 PM = Family Guy on FOX
9/30 9:30 PM - 10:00 PM = American Dad on FOX
10/7 9:00 PM - 10:00 PM = MythBusters on Discovery
10/14 9:00 PM - 10:00 PM = The Walking Dead on AMC
I have three stations with four shows I need to record and watch. According to my DVR, it has two HD tuners so it can record/show two at once. Do I need another DVR for the third one? Does TWC even have a DVR that has more than two tuners? I don't really want to wait eight long days and pay, to watch right away, on FOX.com and Hulu.com (Plus) for FOX's shows.
Edited by phildaant - 8/19/12 at 10:25pm
