No mention at all of the new TWC/LA web site format??? Perhaps it's national as well, but for sure it's new in the TWC/LA area.
INCOMPREHENSIBLE!! Can't find things that used to exist (e.g. "
Programming Change Alerts" page seems to have disappeared). And instead of automatically forwarding you to the proper page if you are trying to use old shortcut links you might have created, they just send you to the common new 404 page (which at least is a "generalized starting page"). Actually this is a "fix", because for a long time they simply returned a 404 page advising you that you've tried to access a page that no longer exists!!
Most annoying, however, is that it appears to be built strictly for Internet Explorer at least insofar as the "
Channel Lineups" page goes. You used to be able to use Firefox as well, but no more. When you uncheck the ALL or any of the tiers, it is supposed to instantly re-populate the page with the results of your request. Well, it does ZERO in Firefox, but works properly in IE.
Anyway, it does look prettier and absolutely more modern and elegant. New fonts, new style, everything certainly is sleek and pretty.
But it's radically different than it used to be, so good luck trying to figure out how to use it.
Much like what Yahoo! did with their "Movies" site, which used to be understandable. They brought in some foreigners, apparently, to rebuild that site a few years back, and it's been unusable and incomprehensible ever since. Real shame, as I used to use it all the time. They've actually now tried two additional variations following the initial disaster, but have never achieved the sheer simplicity and usability of the original design... WHICH WORKED PERFECTLY, SO WHY SCREW WITH IT?
Same kind of thoughts about the new TWC/LA site.
