Going back a bit .... meant to comment on this earlier, but didn't have the time :
Originally Posted by
ThoraX695
WCPO will more than likely stop broadcasting on RF 10 and start broadcasting on RF 22. They have permission from the
FCC to make the switch, but haven't submitted a CP application yet.This would also knock off the W22DE analog translator in Dayton.[/list]
The FCC order(Adopted Dec 8, 2009/released Dec 10, 2009) changing the allotment to 22 was Published in Federal Register on Dec 21, 2009 (The "effective date" of the order) ..... It specifies in the order WCPO SHALL submit a CP app (minor change to licensed facility) within 30 Days of the effective Date of the order ...
It's possible they may have already submitted it, and it's just not "showing up" yet (A current search of CDBS doesn't find it yet) --- In any case, one would think it *should* show up soon ......
BTW, Regarding Other recent UHF to VHF changes in area -- WKYT's (Lexington - currently on 13) CP app for 36 Was filed 12/1 -- , WSYX(Columbus - Currently on 13) CP app for 48 was filed 12/28/2009, but not shown as "accepted for filing" by FCC until 1/6/2010 .... The FCC order changing the WSYX allotment was Adopted Dec 8/Released Dec 11, Published in Federal Register December 21 ....
One perhaps interesting thing about that is the only "indication" of the W22DE callsign I can find is on the Authorization for the CP, All other records available on FCC site are "old" records, with the old W66AQ (on 66) callsign and facilities specified ....
Usually, when the CP is applied for(which happened, and was granted in this case back in 2007 per an "interference agreement" with WKEF), the technical info (ERP, Antenna pattern/etc) shows up in CDBS (including TV query) immediately, and that info is also utilized for interference protection calculations by other stations/etc. for channel change petitions/CP apps/etc per OET bullitin #69 .... Even though they would be displaced, being a LP station -- nevertheless, the info *should* have been there for interference analysis purposes for WCPO's petition as well as the presumably upcoming CP app (especially since it's not just an "app", they are actually ON the air) ....
My best guess as to why that happened may involve that WKEF 22 (analog) was "using" channel 22 in Dayton at the time the CP for W22DE was granted, so perhaps CDBS had some sort of a "key field" issue/etc .....
