Originally posted by William Smith
Okay, I'll give you a choice... 720p or 480p Widescreen for KET4 or drop the HD all together...
William
If it were my choice, given the circumstances involved for KET digital presently, I'd likely chose 480p for KET4 during "HD/PBS Widescreen" programming. Couple of reasons :
#1). At least presently, much of the PBS 16x9 programming broadcast at 720p on KET4 is SD widescreen source material anyhow.
#2) I'd of course prefer HD, but since I'm not being given the choice of 1080i HD at 18mb/s+, or 720p HD at 14~16mb/s .... I'd rather see "compression artifact free" 480p than a dancing Indian that turns into macroblocks at 720p. To me, even 480p 16x9 ATSC format is a BIG improvement over letterboxing 16x9 programming inside a 4x3 "SD" frame.
Of course, that's just me, and without actually seeing it to see what it looks like at 480p. The only time I've seen 480p 16x9 ATSC format was via KET4 before you upgraded your STL for "full bandwidth" ATSC, so I'm just guessing it looks "pretty much" like a DVD via component video with 16x9 NTSC Video scanned at 480p.
Of course, others might have a different opinion, perhaps especially others whose only available source for PBS HD is KET4. Just a suggestion, but, if it doesn't cause too much "difficulty" maybe you could try it at 480p and see what viewers think ...
Granted, 720p from KET4 looks better, overall, compression artifact wise than the present state of 1080i from WCET-DT and WPTD-DT. But, when especially demanding sections of HD programming are involved, at least to my eyes, there doesn't usually appear to be all that much of a difference in artifacts among the 3 stations, presently.
You might not believe it but I worked for weeks to get the HD feed looking as good as it does ....
I believe it, especially since I remember some of it. I should have provided more clarification, but my earlier comments concerning station personel watching HD from their stations certianly wasn't meant to be directed at KET engineers, or any broadcast engineer at the local stations for that matter.
Also, I certianly appreciate the DTV/HD work by yourself+others at KET. When you first started doing HD earlier this year, I thought 720p was the best thing you could have done, and was the best overall compromise given the circumstances involved. But, now I think there's just no escaping the fact 720p really needs more bandwidth than you can allocate to HD given KET's present "DTV situation".
Right now the system has to support KET1 and KET2 24/7, KET3 20hrs/day, and KET4 SD for 20 hrs/day... minimal.
I certianly understand that KET is in a "unique" situation DTV wise --- For example, where providing educational programming to schools is concerned, and also on the technical side of things to "feed" KET1 statewide analog transmitters and WKMJ/KET2 transmitter/etc ... The way I understand it, KET's situation is not common to the other local PBS affiliates here.
Personally, where KET digital specifically is concerned, I'm just glad to have "snow free" and dropout free reception of KET1 via OTA DTV from my location, as I've been watching KET1 with "snow" via WCVN 54 for some 20 years, mostly for programming produced by KET which I enjoy. Where PBS HD is concerned, I'd be happy if just ONE of the 4 local PBS stations would allocate "enough" bandwidth to HD so compression artifacts aren't a problem. It doesn't HAVE to be KET, especially since there will soon be 3 PBS digital affiliates broadcasting from towers within 6 miles of each other in Cincinnati/N KY. And, I'm also already happy with WPTD-DT/ThinkTV's current HD schedule, as well as their plans to expand their HD service in Janurary.
I guess the thing that gets me is, the stations in the area, for the most part seemed to stay on the air for 30-50+ years by broadcasting a SINGLE program service per station. Now, with HD, the quality of service I'm getting is often suffering because broadcasters want to have their cake and eat it too.
For instance (not in KET's circumstance as I understand it), it seems broadcasters want to reduce HD quality(and therefore reduce their level of service to me, in my case as an over-the-air viewer) so they can be a provider of multiple SD services to cablecos+their subscribers, or to serve "paying customers" via subscription servies such as datacasting.
As I said before, it's certianly understandable that broadcasters want to make the most out of DTV -- But, like it or not, HD is one of the improvements we are getting from DTV --- An important one for those of us
whom have purchased or will purchase equipment for HD. We expect our local stations to provide "high quality HD", and SD too for that matter. So, it's a pretty hard pill to swallow that whenever "stuff moves around too much", when stations aren't allocating enough bandwidth to HD it ends up being the case(given good "reception") we receive better quality from NTSC analog SD ...
Sure, I'd like it if we could all have our cake and eat it too, I'd like to have compression artifact "free" HD alongside 2, 3 or even 4 SD services with quality programming available from each station "free to air", but we can't.
Beyond available oppurtunistic bandwidth, Multicasting when HD isn't "available", or 720p+1 SD program service(or equivilent bandwith used for datacasting/etc), more RF bandwidth would have been the only way to have our cake and eat it too, and we know that didn't/isn't going to happen.
Also, there is the old saying, "give'em an inch and they'll take a mile", well, in many cases(at least in our area) it's a saying that seems to be very accurate where DTV/HD broadcasting is concerned.
So, I hate to see it happen(and I know this unfortunetly likely won't happen), but since broadcasters can't seem to "figure it out for themselves", what I think really needs to happen is : Picture Quality/Minimum bandwidth standards for OTA HD AND SD via ATSC need to be mandated. And, given the apparent stubborness of many broadcasters on this issue, since this might mean some broadcasters would just "drop HD" because of quality standards, it seems this would also mean HD would need to be mandated.
Just my .02 ....
When the PBS HD service starts in December something might change a little.
Good to hear some potentially good news --- That is, if this ends up meaning more HD/PBS widescreen from KET4, or if the HD could get a bit more bandwidth ..
