Originally posted by voyager6
I have been seeing a lot of unusual Tropo interference in the last week, but the problems receiving WXIX-DT have been pretty consistant.
Greg
Greg
Sounds like your and Paul's WXIX-DT reception problem is due to their problems ... once you get out probably 45-50 miles from Cincinnati(or have serious terrain issues, or are using indoor antennas/etc), power is probably going to be more of an issue in many circumstances, and especially so on UHF. WRGT-DT being right next door probably doesn't help Dayton folks out either, since your receiver has to be a little more selective to be able to tune in the weaker, adjacent channel signal. Speaking of WRGT-DT, surely would be nice if they'd do Fox widescreen, it's nice to have a "backup" station ...
Anyhow, FCC Info shows WXIX-DT licensed at 229KW ERP, So at 25%(depending upon how they are figuring that), they're probably running something like 50~60KW ERP ... Forward Power that is, I'm afraid to ask how much is being reflected through their antenna/feedline system ....
If they are going to be running low power for any appreciable amount of time, they would likely need to file for a STA, which should hopefully show up in FCC CDBS database ....I do see WKSO 29, Somerset, KY quite often(In same direction as wxix) when WXIX-DT is down, though.
