Some various wondering thoughts ...
Looks like KET is using the add'l subs(54-5/54-6) for their KY General Assembly coverage, so I'd WAG it's temporary ...
And Yes, as allways thanks to Charles and William for participating here ...
Clarke,
I think you might have said you have a terrain issue towards Dayton(which would probably be quite "limiting" in combination with your distance from Dayton on Hi-UHF 58 especially), but if you could see it, I think you'd be pleased with WPTD-DT Dayton. Although Pixelization/limited HD bandwidth due to 2 SD subs alongside HD is a problem at times, WPTD-DT is broadcasting the PBS HD channel overnight(nightly) from 6~8pm or so to 6am ...
Concerning WPTO-DT -- According to info at FCC site, Their Original CP was for WKOI's Tower(is between Oxford and Trenton, OH), but they were granted a CP MOD(On 1/24/03) to use WXIX's tower instead. Given WPTO-DT/WXIX-DT are going to be on 1st Adjacent channels, I think its probably especially a good thing to co-locate 1st adjacent channel facilities ...
WPTO-DT's App "list" with links(If you check out the "application" links for the DT, it explains the hows and why's/etc, including the reasons for their filing for CP extensions) :
http://svartifoss2.fcc.gov/cgi-bin/w...ility_id=25065
Anyhow, I'm allways a little "skeptical" when I hear a station has plans to come up in the middle of winter, as, if the tower work hasn't been done yet, I'd think it probably isn't going to happen until at least spring(Of course, there is the "wind issue" we sometimes have to deal with around here in early spring, too ... Of course, when I spoke to Elliot Block at bqc' in August 2002, their plans at that time were to have WBQC on 38 by Spring 2003 ....
Concerning the "Transmitter virus" (LOL!) -- No telling what "Murphy" is up to these days ....
Oh -- On WXIX-DT .... They seem to be off air currently --- I did notice that although all seemed well prior to last night( the last couple of days when I've checked), Last night, I had solid reception from them during Widescreen "24", but just Barely ... Signal quality meter was showing about 35-40% (Unless they've been off air, It's allways been 95-100%), which is what I get from WKOI-DT this time of year. I can't get WKOI-DT once leaves come on trees, or there's too much wind - I also have a serious terrain issue in their direction - Not an issue for their analog, but their DTV transmitting antenna is much lower on their tower, and of course they are running an 18 KW ERP STA with a directional antenna that doesn't favor my direction --- According to antenna pattern on FCC site, they should be throwing about 2KW ERP in my direction ...
Concerning WKOI-DT(TBN) ... Anyone know how to get hold of them? They are using one of the 16x9 ATSC formats, and they are sending their 4x3 video "stretched" into 16x9 (jst like WXIX-DT's local commercials when they're doing Fox widescreen properly) -- It looks bad+They've been doing this for almost a year now ... I can't squeeze it back to normal proportions in most cases with my 2 setups(except for at 480p/480i on One setup), can't tell if they are sending 1080i/720p or 480p 16x9 ...
