Following is probably more than anyone wanted to know, but follows are my WKRC-DT observations concerning their recent signal improvements :
WKRC-DT Signal strenth:
Looks like signal strength wise, I'm getting about the same from WKRC-DT and WLWT-DT now here, which makes sense. The difference between 800KW ERP and 1000KW ERP is only a fraction of a db.
Compared to -43db for WKRC-DT/-45db for WLWT-DT when I checked it a couple of weeks back, I just checked it and can still just get perfect reception(~33% signal quality reading from this receiver) from either WKRC-DT/WLWT-DT with -45db attenuation added to feedline(includes an estimated ~2.5db loss from the ~65FT coax run).
So, it seems a couple of db "better" from WKRC-DT, but it is hard to actually say if there was any change in the noise floor(co-channel interference/any IM present etc) ....
I expect how much extra attenuation I can add between antenna+receiver and still be able to decode the signal involves a variety of factors, including signal strength and signal quality, receive antenna gain("supposedly" 16db on Ch 31 in this case according to manufactuer), preamp gain(29db in this case)/Noise figure, overall noise factor of receiving system(which should be right around ~3db(close to the preamp NF), the Receiver's AGC circut/etc/etc/etc .... Of course, ATSC specs say 15.9db SNR is required for perfect DTV reception, so at least that's somewhat of a "given", and that threshold should be close to the 33% signal quality reading on zenith receiver which is generally required for perfect DTV reception ...(a PSIP lock occurs at about 28~29%) ... And, that ~16db threshold SNR I'd think should also roughly equate to the 41dbu signal contour defined by FCC as a DTV stations coverage area(given a 10db receive antenna at 30FT AGL If I recall correctly, although FCC's contour prediction methodology doesn't take terrain into account) ....
Since I don't have any equipment such as spectrum analyzer, I can't vouch for how "accurate" my readings are, only that it should be fairly accurate in the sense that if I add an attenuator marked "10db attenuator", It should be actually attenuating signals passing through the coax by 10db, a 2 way splitter should be 3db insertion loss/etc/etc, an adustable RS attenuator(to max -20db) should be adding -20db attenuation of knob is fully clockwise/etc/etc .... It would of course be better, and probably produce a bit more accurate estimate of signal strength at this location to take out everything(especially the preamp) between the receiver+antenna except for the coax+a balun+then estimate the antenna's gain and subtract estimated feedline loss, however, as among other things that would also be very inconvienient since it would require removal of rotor, lowering of mast, getting my VHF antenna out of the way/etc/etc to remove mast mount preamp ...
Anyway, also It is taking -18db attenuation before signal quality readings from WKRC-DT start dropping any from 95~100% on Zenith HDV420 receiver.
WKRC-DT Signal Quality:
What has been a more noticable improvement is that prior to their improvements -- for about the past couple of years sometimes, the signal quality meter on Zenith receiver would only show a maximum of about 80%, and sometimes it would show about 80% for a few seconds when first tuning to the station, then afterwards it would go up to 95~100%, and sometimes it would show 95~100%, even when first tuning to WKRC-DT ..... I couldn't quite figure it out, my best guess was that it had to do with the signal being so strong along with what the receiver's AGC was doing. But, Now, it's allways a solid 95~100% so apparently the signal quality improvements at WKRC-DT did the trick.
BTW, With the DTC-100(which is currently out of commission, I can't check it currently), it would show between 76~82 most of the time, except prior to about two years ago, it was allways showing an "88" reading. It seems to like "88" for some reason, that's what it pretty much says for most ofl the Dayton/Cincy stations ... except WLWT-DT, which shows up as 90~94, and WRGT-DT also 90~94, and WCVN-DT usually "82" but sometimes 86~88 ....
possible WKRC-DT channel mask improvement? :
It's a little hard to say/tell but, on ch 32 using a analog, non-screen muting TV and looking at the "snow"(Snow from a strong DTV station appears as a sort of "big" horizontal snow on some analog TV's, either depending upon how AFT is implemented, or NTSC tuner which allows manual "fine tuning") it looks like WKRC-DT may have improved their channel mask a bit ... Can't really check anything on 30 in this regard, because of WRGT-DT 30 Dayton.
Attached is a series of screenshots to demonstrate(with antenna aimed at Cincinnati of course). At upper left shows the "snow" on Ch 32 if I have the tuner set at "-05" offset for ch 32. (Note -05 offset on this tuner seems to usually do the best job with weak signals on nearly all channels). As you can see, It's pretty much "clean" looking ordinary "snow"(The brighter white "band" 1/3 of the way down is a camera "shutter speed"/etc. "artifact") - probably mostly from noise in the front-end of receiver/preamp, but also somewhat from background radiation from the "universe"(you know, the dancing "ants") ... At upper right, shows the snow on Ch 32 with -08 offset on the NTSC tuner ... You probably can't tell much, if any difference via this screenshot, but if you could, in "real life" that was about what "-05" on Ch 32 looked like here before WKRC-DT made their improvements(The slight bit adjacent channel interference/"slop" was more evident when a actual NTSC signal from WLKY 32 Louisville is present).
So, It does seem to be a noticable improvment. The lower pic shows what WKRC-DT's "DT Snow" looks like via with a -17 offset on this NTSC tuner, tuned to ch 32(I wish I knew what the actual "center" freq. was, instead of just -17/etc). Note that with WLWT-DT, on ch 36 it looks pretty much the same with these same offsets, except that I'm currently(as is usually the case) getting a weak and somewhat unstable signal from WTVQ 36(analog), Lexington, which does looks quite "clean" with an offset of "-05" ...
Having come across very little info on it I have allways wondered, when working with strong signals what the 1st adjacent channel situation would be like for weak 1st adjacent channel signals(analog or DTV) if the signal modulation being used was COFDM instead of 8VSB ...
