Here are the results of my first attempts to tweak the user menu with Digital Video Essentials (DVE). The setting bars in the GWIII user menu have 64 positions, and I'm counting the lowest position as 1 here, not zero. So the full range is 1-64. This is how umr does it in his tweaks document.
For 480p, 720p, and 1080i, I've modified Standard and Pro as follows:
Mode: Standard
Picture: 80% (51 ticks)
Brightness: 67% (43 ticks)
Color: 44% (28 ticks)
Hue: 47% (30 ticks)
Sharpness: 50% (32 ticks)
Color Temp: Warm
NR: Off
Mild Mode: On
Mode: Pro
Picture: 88% (56 ticks)
Brightness: 61% (39 ticks)
Hue: 47% (30 ticks)
Color Temp: Warm
NR: Off
Mild Mode: On
For 480i sources, I modify the following settings from what you see above:
Mild Mode: Off
DRC Mode: High Dens.
DRC Palette: Reality = 1, Clarity = 100
BN Smoother: Off
My Pro settings definitely have more shadow detail than my Standard settings. This was especially apparent in the DVE grayscale ramps. Even at identical user menu settings, Pro just does a much better job showing the different gradiations of near black.
I haven't done that much testing with different material, but my Standard settings seem to be better than Pro for SD, I'm not sure why. Pro looks a little too blurry. If I turn on CineMotion for SD, both Standard and Pro get too blurry. I'm also unsure about the NR and BN Smoother settings. With DirecTV SD, I couldn't notice any difference when changing these, so I left them off.
For HD, I think my Pro settings look a little better than Standard, but they're pretty close. When switching between Pro and Standard (the remote Picture button is great for this), I can see some shadow details come to life when switching to Pro.
These Standard 480i settings look very good for 480i videogames. I haven't tried a 480p or 720p game since making the changes.
Other than DVE, I didn't test any DVDs, so I'm not sure which setting is better there. I would suspect Pro is better, at least for progressive scan.
Quick tip if you didn't realize it, when in a user menu, you can press the Reset button on the remote to revert to the default settings. For example, if you're modifying the Pro settings, hitting the Reset button will change the Pro settings back to their factory defaults.
EDIT: My latest settings are in this thread:
GWIII and DVE
I'll keep my post in that thread edited to reflect any changes I make to the user menu settings.
Mode: Standard
Hue: 47% (30 ticks)
Color Temp: Warm
NR: Off
Mild Mode: On
Mode: Pro
Hue: 47% (30 ticks)
Color Temp: Warm
NR: Off
Mild Mode: On
Mild Mode: Off
BN Smoother: Off
GWIII and DVE
