Originally posted by mikemav
I posted this to a new thread last night by accident, so I'm sure it was missed by most. Meant to post it here.
Sorry if this has already been covered. I am just starting to play with DVDEdit. Thanks for your hard work NiteOwl. I see when a disc has cover art on the Entre I can see it in the application. Is there a way to edit it or insert cover art for DVDs without a specified cover in the Entre already? Also, I see there are two XML files created, on listing DVDs and ratings, and one with descriptions. Has anyone tried importing this info into DVDProfiler or DVDLobby yet? Would having two XML files confuse the third-party app, or are they both not needed? Thanks
NiteOwl has worked incredibly hard on that application and it is a several releases ahead of what is on that website where I assume you got it. Several of us are beta testing it and providing feedback. He worked through some tough issues. He is in the process of allowing coverart to be uploaded (from PC to Entre) and associated with the DVD being edited. He is still working the kinks out and adding resilency code.
No mention of importing XML from Entre to DVD Profiler. If you compared the information exportable from DVD Profiler to what is in the Entre's XML it is very lopsided...that is DVD profiler would be better as the source to populate the information in the Entre.
The need seems to be when OG look up fails and you want the basics: Coverart, title, and category/genre, and overview. To me cutting-n-pasting the information beyond that does not seem like a good use of computer cpu . Coverart, title and overview is about all the energy I want to give out. Now if I could do a click or two to sync a DVD with my DVD Profiler XML then that is easy enough.
