Originally Posted by
KML-224
Wait...WSAH-DT 43-1 would also be WTNH-DT 8-2? Is that what you're saying?
Yes, it's a possibility. The whole idea of WSAH renting one of WTNH's subchannels was so that Channel 43 could continue to have approximately the same footprint in Connecticut even after it is allowed to move its antenna to New York City.
I looked at the service contour maps for WSAH-DT on the FCC website. The coverage map for their signal if broadcasted from the Empire State Building shows that it would only reach into Connecticut as far east as Danbury and Bridgeport. The signal would basically only cover the "tail" of the state. The other coverage map with WSAH broadcasting from the current tower (owned by Comcast) in Seymour, CT shows that WSAH's signal extends as far north as Southwick, Mass., and covers most of western Connecticut.
By leasing one of Channel 8's subchannels, WSAH's current coverage could be maintained because WTNH also covers the same area (plus a little more). While it does seem unusual to have the same programming service on the two partially overlapping stations, WSAH is technically in DMA #1 (New York City), and WTNH is in DMA #30 (Hartford/New Haven). Time will tell if the Retro TV Network does show up on WTNH-SD.
KML-224
OK...with a week to go ... Does one station give you more problems than any other? ...
Despite five different antennas and three different receivers since February of 2002, there always seems to be the same list of stations that have given me reception problems. I have always had trouble with WTXX. I have tried to watch the This Network on 20-2 and have gotten one hour and forty-five minutes into a movie without a problem, and then the picture will break up into long horizontal bars. The bars on the top and bottom of the screen will be from a scene that has transpired a minute previously, and the center of the screen will have frozen bars from a more recent point in the program. The audio will become a constant stream of hiccups, making the dialogue completely unintelligible. Hopefully the situation will improve when 20 moves to its higher antenna on the Chase tower and its antenna pattern becomes more omnidirectional. I don't expect to ever receive WCTX or the Ion affiliate from New London. WGGB from Springfield is currently too weak to come in, but that may change when it moves to a higher antenna and leaves digital channel 55 for channel 40.
