Originally Posted by gl1000
Hi,
I am new to this forum and needs help. I live in Madison of CT. I can put in most local channels except ABC (high VHF 10) with an old rabbit ear, but the signals are not strong and I have to move the small antenna around for individual signal. I am wondering if a roof top CM4228HD would help. The signals come from two different directions (North-Hartford/West-New Haven). I am also wondering if I can pull in signals from further away, like NY, with this antenna.
Thank you very much in advance!
Hi,
Wow, you're pretty lucky. I had no luck getting anything my rabbit ear contraption. The only place in town that would have a shot at getting NYC channels would be right by Hammonasset, or a ways out on Neck Road, as it would be mostly over water or low coastal areas to NYC, but even then, probably not, and if you were able to pick something up, you'd need one heck of an antenna.
You *might* be able to get something from Providence if you have a really good antenna, but again, probably not.
There are 1 or 2 stations out on Long Island that are within fairly close range.
It's surprising that WTNH is the one you can't get, they have a strong VHF signal that really travels. Back before the cutoff, I could get the analog channel 8 with a coat hanger... totally pointless but kinda fun!
JUST KIDDING!!!
