Updated November 2, 2003
rtvPlayer 0.92 is a Windows-based video player for MPEGs extracted from ReplayTV 4000, 4500, 5000, and 5500 recorders. rtvPlayer supports automatic skipping of commercial segments and these
rtvPlayer features:
* Automatic or manual AutoSkip for commercial or content segments
* Overscan elimination (now the tops of your videos won't "dance")
* Aspect Ratio control (clips the black bars on "widescreen" shows)
* A segment bar to show which parts of a show are content vs commercials
* Segment editor to add or delete segments or adjust the times when they begin or end; segment info can be saved for rtvEdit
* Playback looping by selecting a portion of the video from the segment bar
* Adjustable Instant Replay duration (7 to 120 seconds)
* Adjustable Quick Skip duration (15 seconds to 3 minutes)
* Replay-like keyboard navigation for absolute and relative jumping
* A full keyboard interface for all controls
Here's the user interface, minus the video part of the window:
http://inside.drexel.edu/ksb/rtvPlayer/rtvPlayer091.gif
Requirements:
* An MPG and the corresponding NDX (for 4000's and 4500's) or EVT (for 5000's or 5500's) file
* Windows XP, 2000, or 2003 (Windows 9x has not been tested)
* Windows Media Player 7.1 or higher (only tested with 9)
* Microsoft .NET Framework 1.1
The current version is available at http://inside.drexel.edu/ksb/rtvPlayer. I look forward to your comments.
--Ken
rtvPlayer features:
Requirements:
--Ken
