Current Stations (1-17-11):
WNDU-DT (42) 560 kW @ 282m HAAT - 800 kW @ 309.7m HAAT Requested
16.1 HD NBC
16.2 SD (simulcast)
Analog ceased programming February 16th at 11:59pm and ceased transmission March 3rd at 7:52pm (2009).
WSBT-DT (22) 266 kW @ 332.6m HAAT (was 280 kW @ 239m HAAT on channel 30)
22.1 HD CBS
22.2 SD "SBT2" (carried in Analog on most area cable systems and DISH Network)
22.3 SD Weather video
Analog ceased programming February 17th at 6:30pm and ceased transmission at midnight.
Digital transmission on channel 30 ended simultaneously and was moved to channel 22 by 12:02am February 18th.
WSJV-DT (28) 250 kW @ 335m HAAT (was 42 kW @ 315m HAAT Directional on Channel 58)
28.1 HD FOX
Analog ceased programming February 17th at 9:00am and played an educational "nightlight" loop.
WNIT-DT (35) 50 kW @ 332.9m HAAT - 85 kW @ 332.9m HAAT Directional Requested
34.1 HD PBS
34.2 SD (simulcast)
Analog ceased programming and transmission on March 12th, 2008 (transmitter failure).
WHME-DT (48) 300 kW @ 295m HAAT Directional - 640 kW @ 306m HAAT Requested
46.1 SD LeSea Broadcasting (religious)
46.2 SD LeSea Network
Analog ceased programming and transmission on January 16th, 2009.
A digital channel change to 46 has been applied for.
Low Power
W18CF (18) 8 kW @ 85m AGL Directional Granted - CP for Flash Cut Expired 3/16/2009
This station was sold by TBN to Daystar in March 2010 and fell silent at that time.
A displacement application has been filed to move to channel 16.
WCWW-LD (27) 15 kW @ 292m AGL
25.1 HD CW
25.2 SD "THIS Michiana"
This is a digital companion channel for WCWW-LP (25).
WCWW-LP Analog went silent 12-28-2010 due to equipment failure.
WBND-LD (49) 15 kW @ 304m AGL Directional
57.1 HD ABC
This is a digital companion channel for WBND-LP (57).
WBND-LP Analog went silent 12-28-2010.
WMYS-LD (23) 15 kW @ 284m AGL Directional
69.1 SD MyNetwork
This is a digital companion channel for WMYS-LP (69).
An analog channel change to 34 has been applied for to clear up interference between 69 and emergency service radios.
WMYS-LP Analog went silent 11-30-2010 due to a faulty power supply.
WYGN-LD (10) 15 kW @ 338m AGL (WYGN-LP 12 3ABN Berrien Springs, MI)
10.1 SD "3ABN English Digital TV"
10.2 SD "3ABN Latino Digital TV"
10.3 SD "3ABN Proclaim Digital TV"
10.4 SD "Hope Channel"
10.7 Audio "3ABN Digital Radio"
10.8 Audio "Radio 74 Christian Digital Radio"
Original 10-27-03 Post:
I havn't seen many South Bend Indiana posts here ... and I suppose that now I have my receiver, I might as well start.
Current Stations:
WNDU-DT (42) 310kW - future 1000kW
Digital 16.2 is simulcasting Channel 16
WSBT-DT (30) 280kW - future 400kW
Digital 22.1 simulcasts Channel 22 in 16.9 widescreen with side bars or HD when available
Digital 22.2 is UPN Michiana (and is carried in Analog on most area cable systems)
WSJV-DT (58) 10.5kW - future 671kW
I cannot receive this channel at all
WNIT-DT (35) 40kW - future 50kW
Digital 35.1 is PBS-HD "American Public Television" - With a slight audio delay behind picture ... - Program is unrelated to WNIT
Digital 35.2 simulcasts Channel 34
(Note that the Main Channel is 35 not 34.)
WHME-DT (48) 4.5kW - future 300kW
Digital 46.1 simulcasts Channel 46
This channel has plenty of glitches ... must be the low power
Nobody seems to be broadcasting their PSIP guide information properly --- not even WNDU which is Licensed (the others are operating STA). And as noted, WNIT is using the "wrong" Main Channel Number on DTV.
JL
16.1 HD NBC
16.2 SD (simulcast)
22.1 HD CBS
28.1 HD FOX
34.1 HD PBS
34.2 SD (simulcast)
Low Power
25.1 HD CW
57.1 HD ABC
69.1 SD MyNetwork
Current Stations:
JL
). I also mentioned the stretch.
